CR250 80W Gear oil or 10W 40?
12 replies to this topic
  • yamarider426
Posted April 09, 2009 - 06:23 AM
Hey Guys I need some help here
Just rebuilt a 1990 CR 250 and in the manual it says to use 10w 40.
Its been a while since I have messed with a 2stroker but it seems I used to run some honda gear oil 80w in my old bike.
Any sugestions?
  • russell3
Posted April 09, 2009 - 06:34 AM
As long as ur bike is stock, I would trust the manual. If in doubt, call the honda shop and they should be able to tell you over the phone.
  • 4 STROKER
Posted April 09, 2009 - 07:32 AM
Both will work just fine. A lot of riders use Rotella T 15-45w with great success, just change any oil you use often.
  • Kyron
Posted April 09, 2009 - 12:40 PM
Your going to get many diffrent opinions........
I've used everything from cheapy 10-40w to 80w and that Rottela, even Automatic Trans fluid and GM auto-trac fluid (transfercase oil)
It will alll work........
IMO what is more important is that you change it.
  • Big_G_Hall
Posted April 09, 2009 - 12:54 PM
10W-40 motor oil is basically the same viscosity as 80-85w gear oil. I run Honda HP 80-85w in my 250. Everyone has their own opinion...but like russell said, you can't go wrong sticking to the manual.
  • russell3
Posted April 09, 2009 - 01:33 PM
Didn't think they were the same viscosity...is it a diffent standard of measurment or something? They do feel close, but most oils feel close to me...I couldn't tell the difference too much by feel. I can tell when I use 20W-50 in my xr600 when its 20 degrees out...it's like molasses.
  • CV4
Posted April 09, 2009 - 01:47 PM
Motor oil and gear oil are rated differently. An 80w gear oil is about the same viscosity as a 40w motor oil.
I use Rotella with no problems.
  • Big_G_Hall
Posted April 09, 2009 - 01:53 PM
20 degrees out! Dang man that's cold...
http://www.amsoil.co...roilbasics.aspx
  • russell3
Posted April 09, 2009 - 01:55 PM
Good to know! I didn't know they used a different rating system. I always thought it was the same.
  • russell3
Posted April 09, 2009 - 02:02 PM
Nice article! It's all great stuff to know. I live in utah and on winter days, it got COLD! Usually in my xr600, i would go down to 10-40 and then switch back to 20-50 in the summer because it was really hot in the summer. With 20-50 in winter, I could barely get it started and then sometimes I could hear the valves for a second or two because of no lube. :thumbsup: that's why I went to 10-40 in the winter.
  • 1987CR250R
Posted April 09, 2009 - 05:46 PM
Honda transmissions are very tolerant. They'll take whatever you put in them as long as you change it frequently.
  • yamarider426
Posted April 13, 2009 - 09:43 AM
:p Thanks for the advice guys!
  • WoodyHonda166
Posted November 13, 2010 - 03:57 PM
That is the BEST advice! I use PJ1 10w-40 in my CR125. Recently saw an add for Bel-Ray 80w gear oil and thought I had hit the jackpot. Now, I find out that they are about the same viscosity, just rated on a different scale. I would really like to try out 20w-50 motor oil and see how that runs, my engine being a 2-stroke and in the winter at that, I am hoping for the molasses effect on my clutch in any case (using 10w-40, my clutch is constantly changing tolerance according to simple operating temperature, hoping the 20w-50 will help maintain smoother, more consistent clutch operation along with the benefits of added tranny protection).
CR125 High Revving on Start Up by Will I Am
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • Hot  28 replies
NOS CR500R Uncrating by Phuzzy McPhuzzface
Dirt Bike   Make / Model Specific   Beta
  • Hot  49 replies
Deposit is in for a 2017 500 RS through BYOB. Excited! by Ben500RR-S
  • Hot  51 replies
What did you do with your CR today? by thetinkerer
  • Hot  69 replies
optimum lowend torque sprocket size cr80r by ericinkmonster
  • 17 replies
