I know I said this a long time ago, but now it has arrived; my PowerNow for my '03 YZ250F! It is gorgeous, light, very clean, very sano.
For those following along at home, this is the final part in my "mods before I hit the dyno" list. So now that I have it, I made my appointment for Monday! So basically I should have SOME kind of results by Tuesday, if all goes well.
Here's the plan, I can't promise anything, but this is it:
-mount Vortex ignition, but DON'T HOOK UP
-run bike as-is (stock with Boyesen water pump cover and impeller already installed)
-install PowerNow, run bike
-hook up ignition, run bike
-UNHOOK ignition! plug stock back in. install M4 pipe, run bike
-hook up ignition, run (now everything is connected)
-check air/fuel ratio, make sure jetting is right on, consider ambient temp
-keep it only slightly rich, as the temp in the shop will be around 70,
but the coldest I'll probably ride in is the 50s.
-when it's hotter the bike runs richer
-when it's colder the bike runner leaner (cold air, more dense air = more air)
I'm pretty psyched, I have a lot of work to do in a small amount of time if I want to get all these readings. I'll sure try. I'm trying to get everything organized so I can maximize my time there. The coolest part is I walk away with a pimped out 2003 YZ250F!!!! I'm really not coming into this with expectations that EVERY part is going to blow me away with its amazing power readings, but I'm just curious to see what's what. Most of all I want to see my air/fuel readings to help with my jetting of the "overall product".
I'll keep you posted!
-totally pumped
