Moose Handguards: 08 WR450?
4 replies to this topic
  • SC Rider
Posted April 06, 2009 - 05:58 PM
Got a set of Moose handguards.
Question. Anyone have trouble installing these or have any pics/tips? Throttle and Clutch cabe seem to be right in the way for optimal installation/ Mount below (too low) Mount above (too high).
What's the deal? I feel stupid, but just does not seem to fit correctly.
Thanks:banghead:
  • JSanfilippo
Posted April 06, 2009 - 06:48 PM
Rotate the clutch perch and throttle housing up.
Mount handguards in desired location.
Put the clutch perch and throttle housing back.
I have the MSR guards which are the same as the moose. This is what I did.
  • IBLucky
Posted April 08, 2009 - 06:28 PM
You might also have to bend them quite a bit to get them to fit nice. I had to use a vice to bend and shape them a little to get things lined up so I could install the bolts.
  • neevothespaniel
Posted April 12, 2009 - 11:37 PM
I don't seem to have any issues with my Moose Racing handguards. The only problem I had was with the brake light switch which extended the banjo bolt on the front brake reservior (which I had to remove to fit the guards).
Here's some pictures of my setup (bad ones I know cause its pretty dark in my garage). I tend to have my levers set a bit low and the guards straight whic from my understanding of your question should make things worse, but it seems to be fine for me:
  • SC Rider
Posted April 14, 2009 - 05:59 PM
thanks, I think it will just take a vise and some bending on my part.
