YZ450 leaking gas
6 replies to this topic
  • ea844c
Posted April 06, 2009 - 05:18 AM
My Son was riding yesterday and we noticed a gas leak from the gas tank. It was leaking where the shroud bolt to the tank. Does anybody have any ideals how to go about fixing this problem? Thanks
  • wondermuscle
Posted April 06, 2009 - 05:59 AM
It sounds like it is leaking at one of the metal threaded inserts. Is that right?
It sounds like the tank is cracked. If that is the case I would just bite the bullet and buy a new one.
You can try to melt the plastic back together but untimetly it will leak again.
I have found that Yamabond does well for fixing small leaks at mating surfaces. You could try pulling the insert out, and re-installing it into the tank with some Yamabond. You can buy it through the thumper store I think.
What year is it? Many may have stock tanks sitting on their shelf if they have an oversize tank. Check E-Bay.
  • ea844c
Posted April 06, 2009 - 06:24 AM
Yes it is leaking from the insert, and it is a 2003 YZ450F and how do you pull the insert out? Thanks
  • nljustin
Posted April 06, 2009 - 08:09 AM
Bummer dude. Once the tank is compromised like that, it will be very difficult (and unreliable to fix). I punched a hole in an old KTM tank from a zip tie of all things! I tried to fix it, but just didn't hold.
  • ea844c
Posted April 06, 2009 - 09:10 AM
Oh well, after further inspection the the tank has a 3/4 in crack at the insert for the shrould to be mounted. Guess I have to get another tank.
  • badburn
Posted April 08, 2009 - 10:44 PM
im having the same problem with my 03 yz 250 just bought new plastic and i cant get the bolt out cause the bolt and the insert just keep spinning.I have tried everything nothings worked.
  • ea844c
Posted April 10, 2009 - 07:39 AM
I went ahead and bought a new gas tank. Thanks for all the help
  • Hot  47 replies
  • Hot  30 replies
  • 5 replies
  • Hot  38 replies
