fuel leaking petcock
4 replies to this topic
  • sixinchsloth
Posted August 19, 2002 - 10:39 AM
my '01 426 started leaking gas from the petcock yesterday. I've already talked to 2 people who have replaced their whole tank becouse of the tank cracking between the petcock and tank.(factory defect?)anyone know of a quick fix that doesn't cost $200. Please help me!
[ August 19, 2002, 03:06 PM: Message edited by: sixinchsloth ]
  • Hick
Posted August 19, 2002 - 10:53 AM
Replace the whole tank when the petcock leaks?
I won't even go there...
Petcock Seal: 3AJ-24534-00-00 $2.00
Packing: 3AJ-24523-00-00 $3.70
I forget which is which, one is the plastic seal between valve and inlet, one is the o-ring. You likely only need the latter but for a few dollars more...
You can also buy the entire petcock for about twenty bucks.
  • Dean400
Posted August 19, 2002 - 11:48 AM
Have you had the gas tank empty for a while?
I have a WR400 that I drained the gas tank for winter storage. In spring, I filled the tank and the petcock leaked for a couple days, then stopped. I figured that the gasket shrank without fuel, then swelled up with fuel.
  • Thumpin'_Canuck
Posted August 19, 2002 - 07:23 PM
If you need and can't afford a new tank right away you could use JB Weld. It's a super epoxy that comes in larger tubes similar to model glue. You just mix and muck back together what ever you have broken. I once used it on an old snowmobile's crankcase. Good luck. TC
  • Thumpin'_Canuck
Posted August 19, 2002 - 07:26 PM
Note to self: Read posts more carefully. That guy said petcock leak, not tank leak.
