06 Yz450 help
14 replies to this topic
  • 1000k6
Posted April 02, 2009 - 05:15 PM
Hey fellas,
My buddy is having a problem with his YZ-450
the bike will start up perfect with the choke on.
turn the choke off and the bike will not idle, seems to bog under light throttle (pilot) but will stay running if you give it throttle.. just wont idle and seems to pop then die out
  • rdrata
Posted April 02, 2009 - 05:18 PM
air screw?
  • 642MX
Posted April 02, 2009 - 05:19 PM
Sounds like the pilot jet and/or pilot circuit is restricted. Time for a carb cleaning.
  • 1000k6
Posted April 02, 2009 - 05:32 PM
I got it to idle playing with the idle screw under the choke.. is the air mixture screw located somewhere else? please forgive me i've only had PWK carbs.
the bike is still unresponsive/pops under light throttle
  • 642MX
Posted April 02, 2009 - 05:44 PM
Turning the idle up is just by-passing the pilot circuit and its still going to run like crap.... now, go clean the carb. :thumbsup:
  • 1000k6
Posted April 02, 2009 - 05:53 PM
I know, not going to run it this way!
where is the pilot air screw located? i heard its capped from yamaha.
  • rdrata
Posted April 02, 2009 - 05:56 PM
642mx is right, and while you're at it, go with a 45/168 jet combo and put in a finger adjust air screw; I think mine is 1-3/4 turns out. Makes it into a new bike:banana:
  • 1000k6
Posted April 02, 2009 - 06:06 PM
I believe you guys. This bike is not mine
Just want to make sure the stock pilot screw is at factory settings, the bike is fully stock. can you tell me how to get to the pilot air screw? is it on the bottom?
  • 642MX
Posted April 02, 2009 - 06:07 PM
The fuel screw is located on the front side of the bowl, under the carb. Its a real PITA to adjust without removing the carb or swapping out the stock fuel screw for an extended screw. Its not capped.
  • 1000k6
Posted April 02, 2009 - 06:09 PM
thank you very much for your help. greatly appreciated.
  • 642MX
Posted April 02, 2009 - 06:23 PM
No problem. :thumbsup:
Posted April 02, 2009 - 07:32 PM
http://www.thumperta...ad.php?t=696672
The WR is capped, not the YZ.
  • 1000k6
I talked to my friend, He said last time he was out riding it wasnt idling well.
Bike has been sitting for awhile and gas is a year old.
under 10 hours on it since 06, so yeah. the carb is CLOGGED.
I will be pulling the carb off and cleaning it for him, I come from 2-strokes & PWK's..
any tips for the FCR removal/installation/cleaning? any good write-ups online?
Posted April 02, 2009 - 08:35 PM
Year old gas? Forget it. It's a wonder that it even burns.
To ease carb removal, read this thread from here:
http://www.thumperta...759#post7885759
  • brAapingyz450s
Posted April 25, 2009 - 09:36 PM
yea your carb might be clogged with sh1t check it out happened to my dads harley actually from sitting over winter would run with the choke on but as soon as he turned it off it would die
  • Hot  36 replies
  • Hot  113 replies
  • On January 15, 2017
  • 10 replies
