Stupid Question: Exhaust Packing 2t vs. 4t what's the diff?
23 replies to this topic
  • Smacaroni
Posted April 01, 2009 - 06:39 AM
What's the difference between exhaust packing marketed for 4 stroke engines vs. 2 stroke?
  • Romster
Posted April 01, 2009 - 06:48 AM
good question, I want to know too.
Also my stock 4t muffler seems to be riveted together, how would you repack that
  • Bama1
Posted April 01, 2009 - 06:49 AM
some use a "blanket" wrap around the core others use a "pillow" packing around the core but in the end it all does the same thing if you have a 4t get 4t packing and 2t for a 2t pipe
  • Bama1
Posted April 01, 2009 - 06:50 AM
what kind of stock 4t are you running.....i have yet to see a stock pipe that can be re-packed(4t)
  • KJ790
Posted April 01, 2009 - 06:56 AM
Some two stroke packing is not as heat resistant as four stroke packing. Other than that, they are the same. You can use four stroke packing in two strokes just fine (unless it is the pillow packing that is presized, in which case it simply will not fit in a two stroke silencer).
  • WILLIAMS37
Posted April 01, 2009 - 07:18 AM
^^ Good info. I always thought it was just a size thing.
  • dlowe102
Posted April 01, 2009 - 07:55 AM
my 2 stroke procircuit silencer was packed with 4 stroke packing from the factory...that stuff must last forever on a 2 stroke because i went to repack it and the packing is still perfect
  • Smacaroni
Posted April 01, 2009 - 08:12 AM
how to repack a non-repackable muffler:
http://superhunky.co...Mufflertech.php
Thanks for the info 4t in 2t ok, the other way around is a no-go.
I also was wondering what the difference between the pillow vs. pressed is, I just assumed it was a personal preference.
  • ncdirtrider249
Posted April 01, 2009 - 08:33 AM
pillow is a fluffy type substance like the fmf silencer packing...the pressed is the stuff that you get from moose or white brothers (vance and hines)
  • Smacaroni
Posted April 01, 2009 - 08:50 AM
I like the pressed just because it looks easier to work with, but I could be wrong, it's the only thing I've ever used.
But is there a reason other than mine to use one over the other?
  • Smacaroni
Posted April 02, 2009 - 07:56 AM
So I'm to assume that there's no significant performance or installation difference between pillow and pad muffler packing? If so, why would anyone use the pillow since pad looks easier to work with?
  • Bama1
Posted April 02, 2009 - 08:30 AM
all depends on what came out of it.. and what the requirements are...... this may be just me but if pillow comes out. thats whats going back in and besides i figure if you get the right replacement parts it will be easier to work with and fit right
  • rpt50
Posted April 02, 2009 - 01:39 PM
The above post is correct in that 4 stroke packing is more heat resistent that smoker packing. If you are repacking a smoker silencer, don't waste your money buying motorcycle branded stuff. Just go to Lowes or Home Depot and buy pink insulation. It is basically the same thing as 2 stroke packing, it works great, and you can buy a lifetime supply for next to nothing. I have been using nothing but pink home insulation for years.
  • stlavsa
Posted April 02, 2009 - 02:37 PM
Whaaaaaaaaattttttttt????? I got no problem repacking any of my 4-stroke mx bikes. Look on the inlet side of the muffler, not the outlet side...
  • sheas93
Posted April 02, 2009 - 02:49 PM
after how many hours should you repack?
  • Dirty Sanchez
Posted April 02, 2009 - 03:13 PM
It amazes me that people who ride dirtbikes either don't repack their bike's mufflers or don't even know that those mufflers need to be repacked. I think this is far more common than not.
I repack mine every 20-25hrs and I'm only a trail rider. Packing gets destroyed very easily and your bike gets very loud when it does.
  • KJ790
Posted April 02, 2009 - 03:16 PM
All stock MX exhausts require repacking. Here is a good chart that gives a pretty good idea of how often you should repack:
  • Dirty Sanchez
Posted April 02, 2009 - 03:33 PM
oh crap I'm a beginner. :thumbsup:
  • stlavsa
Posted April 02, 2009 - 04:00 PM
haha dont be hard on yourself... that chart seems a little like overkill to me. I just look at the packing everyonce in a while... if it looks deteriorated, or burnt up, it gets changed. When my bike had 25 hours, it was a little burnt up but it was still completely fine.
  • Smacaroni
Posted April 03, 2009 - 04:14 AM
Yeah man, no body has ever been born with a greasy wrench in their hand.
Some of us got one in our diapers and others don't get one until much later in life, but everybody was a beginner once.
Very true, I think most people who don't repack don't realize it's gone because the volume increase is gradual. It's not like a busted chain where everything's fine one moment and the next the bike won't accelerate, no matter what.
I agree with the other poster, pull your exhaust apart every now and then (2t you should be doing this more often because of that wonderful spooge), if it's shot or getting crappy, order new stuff and do it when you have a half hour or so free.
My street bike I don't because the kerker didn't come with it. If it weren't for the jetting headache, I'd probably modify the innards and use muffler packing instead of the blocked perforated tube it has now.
Help with exhaust choosing by GearHeadGumbie
  • 7 replies
KTM and Beta fanboys get ready to pay double for your bikes by cjjeepercreeper
  • Hot  172 replies
My teenage 1996 KTM 125 EXC project by Lanemichael
Dirt Bike   Make / Model Specific   KTM   KTM 2-Stroke
  • 0 replies
Husqvarna TE125 2015 by clappedoutkx
  • Last review by clappedoutkx
  • On January 19, 2017
06 YZ125 Oil Drain Plug Hole Stripped by Just Zach
  • 9 replies
