No neutral on my 06'
3 replies to this topic
  • Schock
Posted March 31, 2009 - 01:00 PM
Hey guys!
Can´t get neutral on my 06' 450 when the engine is running and I´m stopped. I can get neutral when I´m riding or when the engine is not running.
Is that a big problem? Anyone had the same problem?
Thanks for the help and sorry for any mistake in my english
  • MX926
Posted March 31, 2009 - 01:37 PM
Your clutch could be dragging. Sometimes the clutch basket gets grooved up and won't dis-engage all the way.
Posted March 31, 2009 - 01:42 PM
That's normally the cause. Clutch drag (the failure to release completely enough) is usually caused by one or more of the following:
  • Incorrect adjustment
  • Worn or warped plates
  • Grooved/notched basket fingers
  • Grooved/notched boss splines
  • Uneven clutch spring pressure
  • Worn/damaged/warped pressure plate
  • Schock
Posted March 31, 2009 - 03:08 PM
Ok! Thanks for the help! Will open up my clutch to see whats wrong.
  • Hot  36 replies
