KX65 Pre-Mix Ratio
8 replies to this topic
  • SPOOCH
Posted March 29, 2009 - 08:09 AM
The manual says 4 ounces per gallon, 32:1 ratio. What do you use? I have a 05 KX65.
  • martinfan30
Posted March 29, 2009 - 08:17 AM
How is the bike ridden? Raced and strung out all the time, or is it a trail bike?
For racing, a richer oil mix will be needed. Keep in mind, when you richen an oil mix, you have to rejet. A rich oil mix makes the A/F ratio lean out. Meaning richer jetting.
A leaner oil ratio will richen the A/F ratio. So that would mean leaner jetting.
  • SPOOCH
Posted March 29, 2009 - 08:47 AM
This bike will be used by my 8 year old for trail rides. Maybe a hare scramble but not ridden hard.
  • OLHILLBILLY
Posted March 29, 2009 - 08:48 AM
I'd definitely stick with at least 32:1 in the little bike. Most of the time the little bikes get ran a lot closer to the limit than a bigger bike like a KX250 would, so, more oil needed.
Manual calls for, and I use, a 32:1 mix in my KDX even.
  • motoracer11
Posted March 29, 2009 - 02:19 PM
+1 on the trail bike vs race bike mixture....we have a 60 and an 80 and we run 40:1 all the time...both bikes run very well and are very reliable. good luck! :thumbsup:
  • Chokey
Posted March 29, 2009 - 06:43 PM
The KX65 is notorious for losing the lower rod bearing when pushed hard on lean oil ratios. If the kid is really just lugging it around, 32:1 will be OK. If the kid starts getting fast and consistantly screams the engine, you should be running at least 28:1.
  • makKX250
Posted March 30, 2009 - 12:23 PM
I run 32:1 in the son's kx65 for riding the trails. Same gas in my 250 - one less thing for my feeble mind to remember. The guy before me ran Amsoil at 50:1. The engine was worn out and took a new bottom and top end - the rod had noticeable up and down play and the piston skirts were well worn with some blow by half way down the skirts. I'm amazed it ran as good as it did. I probably need to replate when I do the next piston replacement. I'm a firm believer that a little extra oil will not hurt.
  • Jskxrider
Posted April 01, 2009 - 06:12 PM
Pro circuit recomeded 32:1 when I got the engine back from them. Once I jetted it, I have Never, repeat NEVER fouled a plug. Piston has always looked good. IMHO you have nothing to gain by running super lean fuel to oil ratios. Dirt Bike magazine did a test back in the early 90's with an rm 250 running 50:1, 32:1, and 16:1 ratios. It made the most power with the 32:1 ratio, and all the pistons looked good. Just my opinion take it for a grain of salt.
  • JJRace
Posted April 01, 2009 - 07:35 PM
oils have come a long way since the 90s!
But with the stock crank, just a matter of time from what I have been told no matter the ratio. I bought our 65 with a non running motor and promptly put in a new crank, bearings, seals, and top end. No worries about the stock rod issues.
1995 Jetting help - too rich - I'm stumped. by DirtBikeHead
Dirt Bike   Make / Model Specific   Kawasaki   Kawasaki 2-Stroke
  • Hot  46 replies
Fouling plugs! NEED HELP! by Enduro488
  • Hot  29 replies
VIN on title doesn't match frame by Dmangano144
  • Hot  35 replies
Handling and steering on 05-07 kx250's by duner929
  • Hot  32 replies
1990 KX 250 Project. by Richleek2040
  • Hot  30 replies
