how to ease clutch pull
45 replies to this topic
  • hudydog
Posted March 28, 2009 - 06:27 AM
my 03 yz 450 clutch pull kills me I lubed the motion pro cable which helped a little bit. Is there anything else I can do ?
  • wellsy1
Posted March 28, 2009 - 07:30 AM
My buddy had an old cr250 with same problem. He found this easy clutch helper that adds right to your cable. Its kind of funny looking, but it works awsome. But I cant remember who makes it. I do know that when he added it he also had to shorten the cable. Maybe google it? "easy clutch helper"
  • motomanmike26
Posted March 28, 2009 - 07:38 AM
Your cable is worn out. Replace it. :thumbsup:
  • sacfelix
Posted March 28, 2009 - 07:49 AM
If you have some extra cash, you could get a rekluse. Just a thought.
  • motomanmike26
Posted March 28, 2009 - 08:12 AM
Some people don't bother lubing the clutch cables because they say it makes the cables have a shorter life span.
I have never used rekluse so i can't speak for it, it sounds awesome from what i heard but from my past expierences if your getting a new clutch kit, OEM is the way to go. :thumbsup:
  • Valerie Wilson
Posted March 28, 2009 - 08:22 AM
A rekluse is the way to go .... they are awesome.
If you don't want to pony up the $$$ for one of those and easy inexpensive fix is to get an "easy pull clutch system"
http://shop.thumpert...fault.asp?p=592
  • yz426em
Posted March 28, 2009 - 09:33 AM
I would suggest a oem cable with a asv lever, that will make your clutch pull much easier.
  • gbalias
Posted March 28, 2009 - 12:14 PM
MSR pro raptor easy pull lever. $45.
ive got em on all my bikes and would never go back. it gives you 3 selections.
  • FinchFan194
Posted March 28, 2009 - 12:53 PM
I have a teflon coated cable on my bike works great. I think Sunline makes it?
  • keegan1014
Posted March 28, 2009 - 01:09 PM
what about the hydrolic clutches?
I dont know anything about them myself
  • keegan1014
Posted March 28, 2009 - 01:12 PM
like this one
http://www.denniskir...tId=&mmyId=5687
  • FinchFan194
Posted March 28, 2009 - 01:30 PM
like this one
I've never used one seems kinda expensive to me @$244 for only a claimed "up to 20% reduction in clutch pull"
  • keegan1014
Posted March 28, 2009 - 01:53 PM
just an idea
now do the make an auto clutch like the mini bikes
you just shift kinda deal.
I realy only use the clutch to take off than shift off rpms
ive had tons of bikes and no problems with this.
  • FinchFan194
Posted March 28, 2009 - 02:05 PM
Yes the auto clutch is just like whats on a 50/mini. You can also override it with your clutch lever if you need to build RPM's to slip the clutch so it is not exactly the same. I agree though I only use my clutch for starting I slip it once in awhile, but never use it to shift.
  • Colemd
Posted March 28, 2009 - 02:07 PM
Magura hydro clutch
  • gbalias
Posted March 28, 2009 - 04:24 PM
i still think the MSR is the best bang for the buck.
you can get either a shorty or normal. even though the normal one is slightly shorter than the stocker. but it comes with the mount and lever. up to 33% reduction
  • TD-3
Posted March 28, 2009 - 05:41 PM
This freebie mod works well.
http://www.thumperta...ght=clutch pull
  • INJURY_69
Posted March 28, 2009 - 06:54 PM
went i went to a hydraulic clutch I didn't think that the pull was much different.
  • wellsy1
Posted March 28, 2009 - 06:55 PM
I put a Magura hydro clutch on my YZ450f. I love it. It does make it easyer to pull, and I find less arm pump. Track, trail, on road, off road, whatever it gets the job done. But what I like is that there is no cable to adjust ever! All your power is put right to the ground.
  • FinchFan194
Posted March 28, 2009 - 06:59 PM
I agree wellsy1 the only reason I would get one would be for no more cable adjustment.
  • Hot  50 replies
  • Hot  113 replies
