HELP 426 leaking break fluid/ oil?
7 replies to this topic
  • gumbellion
Posted March 27, 2009 - 01:50 PM
Hey
I just picked this up today and after going for a ride I noticed 2 problems. First the front caliper is leaking pretty badly. It looks like its coming from the rubber cover but I don't have a manual. Is that where the bleeder screw is? I just don't want to pull the rubber off and make a mess. The second is the white/Grey fluid coming from one of the over flow tubes. It looks like oil/grease with water in it, but on the dipstick the oil is brand new and full. Help me please guys. In the pic Im pointing at where it looks like the break fluid is coming from
Posted March 27, 2009 - 02:06 PM
The breather goo is normal in humid climates. It's moisture condensing in the hose and mixing with the residual oil there.
The brake fluid leak is a bigger problem. The bleed screw is the smaller rubber cover at the top rear corner of the caliper. The cover you are pointing to is one of the guide pins on which the caliper slides. A leak there often indicates a cracked caliper housing.
  • aj_yz426
Posted March 27, 2009 - 02:12 PM
On the 2nd picture it may be a glare or lighting, but is there oil leaking down at the back of the fork leg? If so, make sure there isn't oil leaking down from the fork seal on that side.
Posted March 27, 2009 - 02:28 PM
That would actually be much more common, and a much smaller problem than a caliper leaking.
  • gumbellion
Posted March 27, 2009 - 03:27 PM
Turns out that I am half blind. It isnt brake fluid but fork oil running down the fork and over the caliper. So do I need to get my forks serviced? Or replace seals? I am pretty sure its not normal judging by the amount. I figured the white oil was fine since its been getting into the teens in the day and below zero at night (Celsius).
  • gumbellion
Posted March 27, 2009 - 03:57 PM
Definately the problem. Whats the fix? Thanks guys
  • gbalias
Posted March 27, 2009 - 04:37 PM
replace your fork seals.
  • aj_yz426
Posted March 27, 2009 - 05:29 PM
you can download a manual free: http://www.yamaha-motor-europe.com/
then service forks and replace seals/oil, pretty easy DIY.
or, take it to a local shop-its a pretty cheap fix.
  • Hot  113 replies
  • 9 replies
  • On Yesterday, 06:20 PM
Motocross
  • Hot  491 replies
