Rekluse clutch great, but...??
8 replies to this topic
  • Yamafun
Posted March 26, 2009 - 06:27 AM
Hey guys, I just installed the Rekluse pro clutch on my '06 WR450. It seems to be doing great, but now I have a lot of 'decel popping' going on. It has all the stock jetting/exhaust on the bike - (even though I have the JD kit, just never installed it). I'm wondering if changing the clutch could have anything to do with jetting..??? And if not, why would I have so much engine popping now? Any ideas?
  • Krannie McKranface
Posted March 26, 2009 - 06:42 AM
My guess:
You no longer have engine braking, so the carb vacuum has changed.
  • slugman978
Posted March 26, 2009 - 08:07 AM
It is not the Rekluse making your bike pop on decel. Your jetting is too lean. Richen up your fuel screw. If you have to go past 2 1/2 turns out, then you need to go up to the next size pilot jet.
  • oldmanx
Posted March 26, 2009 - 11:02 AM
The only time that you lose engine braking with a Rekluse is when you lock up the rear brake. A quick blip of the throttle will re-engage the Rekluse, restoring your engine braking.
Popping on decel is typically an exhaust leak. I just went through that on my WR450. I hadn't replaced the header gasket/donut when I changed headers. A new gasket and some high-temp rtv silicone between the header and muffler cured my popping.
  • h20mn
Posted March 26, 2009 - 02:38 PM
what type of riding do you do, I also have a 06 and thinking of a rekluse. good things and bad things you like
  • ears2244
Posted April 25, 2009 - 01:05 PM
I installed a rekluse z-start on my 08 WR450 and have a few questions. After you installed the clutch does the clutch actuator arm move freely? Mine moves around like there isn't any friction. Is this common? I then tried to install a rekluse clutch perch adjuster and after installation there isn't any play in the clutch cause the cable is too tight. I ordered a new cable but is this the right fix. Any advece will be a great help! Thanks
  • Kirkster
Posted April 25, 2009 - 06:55 PM
I put in a Z-start pro in my 07 WR450 and am not noticing anything adverse. I had a regular z-start in my DRZ400 and ended up putting in a perch adjuster, I did not have to install a longer cable though.
I would give rekluse a call they are very helpful and worked me through an issue with my original z-start.
The pro was worth every extra penny in my opinion. I know that does you no good now.
Good luck. Feel free to PM me if you need any help.
  • ears2244
Posted April 26, 2009 - 05:19 AM
I'll call them tomorrow when they're open. Hopefully I can get this straightened out. On the 07 WR450 they have a cable upgrade for it but nothing for the 08. I think the instructions weren't updated and it left that part out. Thanks for your help.
  • Kirkster
Posted April 27, 2009 - 04:17 PM
07 and 08 are the same bike...
