Tool Kit Question - Axel Nuts
17 replies to this topic
  • 2DTrail
Posted March 25, 2009 - 07:02 PM
I am wondering what you guys do for axel nut wrench in your tool kit. I know the Back is 27mm (don't know the front off hand).
I have a pretty comprehensive yet small, pieced together, kit that I carry which works great. I actually use it when I do all of my maintenance/repairs to be sure nothing critical is missing. Just replaced the water pump seals/bearing/shaft today using my little kit (short of a torque wrench for putting it back together). Now, I know, I wouldn't replace that kind of thing on the trail but it is reassuring that I have the tools necessary for most repairs. Thanks to the WR's design, not much is required.
I was carrying an 8" crescent wrench but it doesn't open wide enough for the rear axel nut. I don't really want to carry a larger one if I can help it. Is there a special wrench made for the WR with the correct size for the front and rear axel nuts, or ??? Any input appreciated!
  • 123BigcoopDawg576
Posted March 25, 2009 - 07:08 PM
For 12 bucks, you cant beat it...comes in handy when need yet still super light :thumbsup:
I carry one for the WR and one for the XR at the same time...that way I dont have to pack my tools every ride :usa:
http://www.rockymoun...7#vehicleSelect
  • 2DTrail
Posted March 25, 2009 - 08:16 PM
That's perfect. Thanks. Just what I was looking for.
  • Birdy426
Posted March 25, 2009 - 08:47 PM
Front is a 24mm. The I have the motion pro versions of those wrench/tire lever combos. A bit lighter, but very spendy. I never would have put "sexy" and "tool" together in this context before I bought those bad boys, but they are sexy tools!
  • spidennis
Posted March 26, 2009 - 09:39 AM
22mm for the front?
and my 22mm motionpro has too much thick aluminum around the wrench to fit properly ...... I end up using a small crescent wrench :thumbsup:
you can see that that metal from the cable guide is getting in the way of the 22mm wrench
  • face_plant
Posted March 26, 2009 - 10:31 AM
www.wheelingcycle.com
search wrench
one is a tiretool, other end is a axle wrench
  • Dube2
Posted March 27, 2009 - 07:20 AM
I have the same one as coop, but just this past weekend I went to adjust my chain for the first time on the 08 and OMG did the dealer tighten that thing up too much. I actually bent my wrench and had to straighten it out again. The one thing you want to remember is even when in the garage working on your bike is to use your trail tools as much as possible. If you cant break it loose in the middle of the desert, your screwed. Not to manny guys (if any) bring a breaker bar in their trail packs. just too heavy.
Also, love the motion pro dual use bars, but damn expen$ive. I have the typical (3)8' motion pro bars with the little nipple on the end. much better than the big spoons. Even at home in the garage, I still use them. Need the parctice since i'm the the only one in my group that has the balls to have a 35lb back pack. I usually fix 2-flats a day in my camp on a big weekend and none of them are mine.
In my rear fender pack alone I carry a 21" tube, (6) paint gun CO2 bottles and CO2 filler, patch kit, (3) 8" motion pro wrench's, and a front/rear axcle wrench. The rest is in my back pack.
  • trailhead2004
Posted March 27, 2009 - 10:11 AM
I concur. Just get the Motion Pro wrenches. And when you're working at home, use them to tighten the axle nuts so you will be able to get them off on the trail if you need to.
trailhead
  • kbike
Posted March 27, 2009 - 11:06 AM
I carry a Craftsman 6 in. Beak Jaw™ Adjustable Wrench, pricey at $25, but sometimes on sale. It has thin jaws that open wide to 28.7mm and guaranteed forever.
  • Birdy426
Posted March 27, 2009 - 02:55 PM
22mm for the front?
and my 22mm promotion has too much thick aluminum around the wrench to fit properly ...... I end up using a small crescent wrench :thumbsup:
You may be right about the size...I will have to double check. I files a bit off of the fork "axle block" to give me wrench clearence.
  • spidennis
Posted March 28, 2009 - 03:24 PM
I'll have to do this myself!
It's nice to have the tire spoons on the other side .....
now I want to have one more as I like three tire irons for changing tires but I don't know what size to choose .....
  • Birdy426
Posted March 28, 2009 - 07:50 PM
Motion Pro also makes one with a 12/13 on one end for rim locks and the spoon on the other. Sa-weet
  • bcs
Posted April 08, 2009 - 10:12 PM
I carry motion pro aluminum tire irons in 24mm, 27mm and the 12/13mm. They work great on the trail--i have used them more than once to repair a flat.
Motion pro makes a 22mm socket that goes in one of the tire irons (i think the 27mm) that is specifically designed for the front axle. Better than carrying an extra wrench. (i carry the 24mm for my DRZ).
  • PBDBLUE
Posted April 09, 2009 - 06:16 AM
It is 22mm for the front and don't forget a 10mm for the pinch clamp bolts.
  • Charles De Mar
Posted April 09, 2009 - 06:24 AM
My Motion pro's have saved the day more than once. Must have, worth the money. It's a small investment when you total how much you spent to be stuck in the middle of no where with a flat. A trashed rim is more expensive. I agree, I use my pack tools to work on my bike most of the time. Pack tools = Garage tools.
  • Birdy426
Posted April 09, 2009 - 06:35 AM
Good call.
  • palmer44
Posted April 16, 2009 - 09:30 PM
This kinda has to do with some of this but what size wrench is it to tightenin the chain i seem to no be able to find the one that fits.
  • PBDBLUE
Posted April 17, 2009 - 05:54 AM
10mm for the adjuster and 12mm for the locknut.
