where to get magnito flywheel puller for WR426
2 replies to this topic
  • pablo83
Posted March 25, 2009 - 06:37 PM
Where do I get a magnito flywheel puller for an 01 WR426? I found an old post with this exact question, but all the links were bad and I couldn't find the right puller anywhere on the sites.
  • Birdy426
Posted March 25, 2009 - 09:08 PM
Motion Pro makes one, but it's spendy. I use a Harmonic Ballancer Puller like this: http://www.harborfre...temnumber=37824
Just be sure that you don't thread the bolts too far into the flywheel or you will damage the coils. I made some spacers out of 1/4" Stainless Steel tubing to limit how far I can thread the bolts in.
  • 02WR426Cali
Posted March 25, 2009 - 09:28 PM
Yep I used the same puller from harbor freight and it's works perfect. The harder part is getting the flywheel nut off without a holder or an impact gun. For that I put two bolts in the flywheel, put the closed end of a combo wrench around one and the middle of the wrench against the other. Not the best way to do it but I got it to work.
