Help Plaese
17 replies to this topic
  • Nathaniel2010
Posted March 24, 2009 - 11:20 PM
ok i rebuilt my carbe put it back together bike started all good but while idling it runs fast then slow and very fast after i rev it or the revs die down nd it stalls while at idle the fuel line was leaking a bit so i'm fixing that now would that cause this or is there a real problem?
Thx for havin a look all advice will be much apreciated
  • schrode
Posted March 24, 2009 - 11:30 PM
leaking fuel can't be helping the situation. fix that first. is the throttle operating smoothly, no hangups? maybe check for vacuum leaks
Posted March 25, 2009 - 06:13 AM
Have you adjusted the idle mixture since you put the carb back together?
  • spark250
Posted March 25, 2009 - 09:31 AM
Definitely try and adjust/fix the items mentioned previously first.
Is it like pulsing with the idle, or would you describe it as a "hanging" idle?
The idle on my bike used to stay high after I reved it and very gradually come down. It was pretty all over the place.
I had to readjust the TPS. Could be something to check?
Posted March 25, 2009 - 09:44 AM
If you removed the TPS, you WILL have to readjust it back to spec per the manual.
  • Nathaniel2010
Posted March 26, 2009 - 12:47 AM
thx guys fixed the fuel leak still did it, so checked and ajusted the TPS and it's all working now thanks for all the help u guys rock
  • Burrap
Posted March 26, 2009 - 07:05 AM
what is tps? the pilot screw maybe
Posted March 26, 2009 - 07:59 AM
Throttle Position Sensor; the electrical device on the left side of the carburetor.
  • spark250
Posted March 26, 2009 - 08:20 AM
Glad it worked out! TPS on a dirt bike was definitely a "new to me" thing when I moved to a 4 stroke.
  • Burrap
Posted March 26, 2009 - 09:03 AM
mine does the same thing and i dont have a manual, does anyone know how to adjust this to spec for an 01' 426?
Posted March 26, 2009 - 09:20 AM
Now you do:
http://www.yamaha-mo...ice/manuals.jsp
  • Nathaniel2010
Posted March 26, 2009 - 11:10 PM
you can get eh manual from here(http://motoman393.th...426_manual.html) it's not in pdf format but still very helpful can be printed so u've basically got ur own book :thumbsup:
  • Burrap
Posted March 27, 2009 - 06:10 AM
thanks a lot
Posted March 27, 2009 - 06:26 AM
The manuals I linked to are also printable.
  • spark250
Posted March 27, 2009 - 06:37 AM
Motoman's site can be helpful but the link gray gives is for the factory service manual. You can't beat those!!!!
  • Burrap
Posted March 27, 2009 - 06:52 AM
im still unclear on what needs to be adjusted or replaced. do i just clean up the wires? Please Help
Posted March 27, 2009 - 08:07 AM
Download the manual and go to page 6-7. The tests begin on 6-8, and the adjustment is on 6-10.
  • Maxed-out
Posted March 29, 2009 - 05:48 AM
HAHA my bike has his same ishew, it takes a while to idle down, but noe to long, enough to piss you off. Any way i was reading my manual on how to adjust the TPS and what a prosses that is! I dont want to even do it!
Now is the TPS very sensitive? To adjust it says to slightly move that unit up or down and align those slots up? I dont know when you start getting electrical involved with fuel im lost after that.:thumbsup:
  • On January 15, 2017
  • Hot  113 replies
  • Hot  36 replies
