top triple clamp from 06 yz
4 replies to this topic
  • Just_a_trail_rider
Posted March 24, 2009 - 10:09 PM
Will a stock top triple clamp from a 06 yz250 fit on a 05 wr450 and vice versa?
I know that the forks are both 48mm. I am wondering if they have the same offset or will I need to swap both top and bottom clamps.
Thanks
  • mikenash
Posted March 25, 2009 - 07:11 AM
I think the off set is different yz's changed from 05-06 year.
  • eazrider
Posted March 25, 2009 - 01:40 PM
Except for the mount for the front #plate, my '06 YZ 450 top clamp works perfectly on my '05 250 2 smoker....
  • yamikenn
Posted June 11, 2011 - 03:25 PM
how ? the 06 clamp according to yamaha they are 1mm apart from each fork, did you use any spacer on the axle , im planning doing this on my yz 250 05 but with top and bottom clamp from a yz450 06 but the fork and the axle that i will not change only the clamp top and bottom.
  • MaxPower
Posted June 12, 2011 - 06:35 PM
[COLOR="Green"]Im not positive about the offset and the forks being further apart but I do know that you will have to make a mount to hold the electrics
[/COLOR]
