Tranny bearing Removal???
4 replies to this topic
  • finthat
Posted March 24, 2009 - 06:37 PM
:thumbsup: Is there a special tool to pull the trans bearing out of the case where the clutch shaft comes across? Or is there a trick to it?
  • finthat
Posted March 24, 2009 - 06:48 PM
By the way I think it is part number 93306-00431-00 if you look it up in the parts fiche on this site at the TT store.
  • 642MX
Posted March 24, 2009 - 06:53 PM
Are you talking about the actuator shaft bearing?
  • txmxer
Posted March 24, 2009 - 07:20 PM
If were talking about the same bearing you can put some ice on the bearing itself, then heat the case (only areas surrounding the bearing) and then it should come out quite easy. If you watch the rockymountain bottom end rebuild videos on youtube one of them mentions it.
Posted March 24, 2009 - 08:25 PM
Yes there is. You need a blind bearing puller. Some car parts places or rental outlets will rent you one.
Heating the case to 260 ℉ (use an oven if possible, if not, heat until spit bounces off) will help. Handle it with gloves while it's that hot. Sometimes you can simply slap the heated case down on a wood bench and dislodge the bearing, but the puller is the way to go.
  • 0 replies
  • Hot  113 replies
  • 5 replies
  • On January 15, 2017
