Clutch
7 replies to this topic
  • DBMX 925
Posted March 24, 2009 - 01:05 PM
2006 YZ450 with 80 hrs. I keep burning up clutches. I replaced the basket and clutch boss, new plates, fiber and steel, 10 hours ago all OEM. The clutch is gone. I use Mobil 1 synthetic racing oil. If the pressure plate is worn, would that cause premature failure? Anyone else have any issues? Thanks in advance.
Posted March 24, 2009 - 01:20 PM
Not likely that it could wear enough to be a problem. The "friction" surface of it is not scored or anything, is it?
You did not mention springs. They're cheap, and should always be replaced.
Neither my son or I have had any issues whatever with the Yamaha clutch. It's not your oil either, as I used to run the same stuff. We don't fan the clutch, or all that other two-stroke stuff, but we're prett tough on the clutch in the tight sections sometimes.
  • Michael Cahill
Posted March 24, 2009 - 07:12 PM
X 2
I cooked my clutch pretty good one day in the woods, pulled out the fairly new clutch, and the clutch itself was still fine.
put in some new springs (OEM) and she was good as new. :thumbsup:
i guess the heat messed with the springs and made them really weak.
i am gunna replace the whole clutch soon, but at the time it was still pretty fresh, so i tried the next cheapest option :usa:
  • 642MX
Posted March 24, 2009 - 07:21 PM
The springs for sure need replaced....
Now, I had a friend with a CRF250 that kept having clutch troubles. He could burn one up in 10 laps (A rider, clutch abuser). The actual problem was a warped pressure plate. It wouldn't warp until it got hot and then the clutch would spin. Something to check I guess....
  • DBMX 925
Posted March 25, 2009 - 12:52 AM
[COLOR="RoyalBlue"]You did not mention springs. They're cheap, and should always be replaced.
[/COLOR]
Yes Gray, I changed the springs too. Maybe I ride a bit 2 strokey........:thumbsup: There are some grooves in the plate, but look machined, if it's supposed to be flat, there is wear.
I am going to order a GYTR heavy duty clutch today, maybe I'll get more life from that. OEM pressure plate is only 31 bucks, maybe I'll just order 1 up. Maybe I should just get a Rekluse and pull the darn clutch lever off. One way to change an old habit..........
  • MX926
Posted March 25, 2009 - 04:30 AM
Make sure your clutch cable has some slop in it at the lever. Many people tend to run little or no slop which can cause the clutch to wear. Changing the pressure plate would be a good move also.
  • rookie23
Posted March 25, 2009 - 04:37 AM
yes check and make sure your clutch cable is not over adjusted and also make sure that you are not way over geared, if you are riding in the woods and catch yourself slipping the clutch to kinda slow down a little to get arond something or over something maybe you should gear down a tooth in the front
  • DBMX 925
Posted March 25, 2009 - 05:00 AM
Well, there was play, you know the nickel thing, all gone now, just like the clutch......................................keep those ideas coming, sooner or later we'll figure it out. Thanks, TT ers
  • Hot  36 replies
  • 10 replies
  • Hot  50 replies
  • Hot  47 replies
