Ranger says my BRP is too loud, need some advice.
9 replies to this topic
  • USNavyMustang
Posted February 22, 2003 - 02:44 PM
This is my first post and I'm hoping someone can point me in the right direction.
In short, my parade was rained on today when a CA park ranger said my bike is too loud. I rang in at 98.5dB and the limit is 96dB.
Do any of you have a suggestion on a decent silencer (or any other tip) that will shave off 2.5dB without compromising performance? My 2001 XR650R is uncorked and properly jetted. I'm using a Pro Circuit exhaust and love the performance I get.
Also, any links to sites that cover this lame CA law which recently changed the dB level from 101dB to 96dB would be greatly appreciated.
Thanks for the help in advance.
I do most of my riding at Hollister Hills located south of San Jose. If any of you ride there (or close by) and want an extra rider to ride with let me know. I'm normally able to ride THUR-SUN, anytime, (disclaimer: schedule subject to change :)).
  • Desert_Racer_X
Posted February 22, 2003 - 07:58 PM
I'm pretty sure PC makes a quiet core insert for your exhaust system. My bet is that it will effect the performance a little. I have a small post card outling the new db requirements I'll send it to you if you want...Id scan it and email, but my scanner is down. Let me know...Good luck
  • CoreyClough
Posted February 23, 2003 - 06:01 PM
Before you buy that insert, buy another spark arester screen fron Pro-Circuit, and fill in the screen from the tip to about 1/2 to 2/3 from the bottom with J. B. Weld. A very noticeable sound difference will result. Repack the can if it has been a while. The object of the screen fill, is the the exhaust will flow around the tip, and not cause a blunt blockage, yet you can still have the same size outlet on the back of the can. The screen is only about $25.00, and you can keep the stock one to use elsewhere. It is worth the investment.
  • marcw
Posted February 24, 2003 - 08:31 AM
Here's a link
http://ohv.parks.ca....p?page_id=22407
I have a whites 96db quiet tip exhaust on my 650 which sounds and performs well
  • USNavyMustang
Posted February 25, 2003 - 07:34 AM
Yeah I was thinking PC made a quiet core insert also. Thanks for the postcard offer, marcw's post below provided what I needed.
  • USNavyMustang
Posted February 25, 2003 - 07:37 AM
Thanks for the link. It is exactly what I was looking for. I will give the whites tip a shot if cloryclough's screen fix doesn't do the trick.
  • USNavyMustang
Posted February 25, 2003 - 07:43 AM
Thanks for the tip. I will try the extra screen thing and see what it nets me.
  • CoreyClough
Posted February 25, 2003 - 08:04 AM
Believe me, it WILL make a difference!
  • secretatlas
Posted February 25, 2003 - 02:11 PM
you can have jerry of 4 stroke works (formerly of stroker) make an insert for you. chances are he can make it cheaper than the PC if the screen solution doesn't work out and you want something sano. check his site out but he's sort of oldschool and would prefer a phone call: www.fourstrokeworks.com
he made an insert for my xrs only pipe which rang in at 108 the little insert he made got my bike down to 98 so i could enter enduros.
  • dans
Posted February 26, 2003 - 03:42 PM
I have the same T-4 exhaust and the same problem with noise.
I spoke to Pro Circuit, they are in in production of a completely new "quiet" system for the 650r and all other popular 4 strokes. I was told they should be available in about 2 weeks. (don't hold your breath)
Dan
  • 4 replies
  • Hot  35 replies
  • Hot  60 replies
  • Hot  186 replies
