O-ring..... Carb Leaking Gas
7 replies to this topic
  • gator4life108
Posted March 21, 2009 - 04:06 PM
Ok, so I have the usual carb pissing gas out of the bottom of it......I have mine apart looking for this o-ring that everyone talks about that is the usual problem.
Where the heck should it be, Im a noob at this, I've looked over the parts manual and Im not seeing anything.
Thanks
  • William1
Posted March 21, 2009 - 05:14 PM
The oring is under the float needle seat. Parat of part #25
  • gator4life108
Posted March 21, 2009 - 08:36 PM
That's what I thought, just I couldn't find a way to get it out.....
Thanks for the clarification tho.
  • Birdy426
Posted March 22, 2009 - 07:59 AM
Take out screw No 26 and the float seat will just pull out.
  • vfr661
Posted March 22, 2009 - 06:53 PM
Instead of buying the whole float needle set for $50+, I replace the o-ring for $0.50 and solve the gas leak problem. After you take out the float needle set, inspect it and figure out what needs replacing. Most of the time it's only the o-ring that needs to be replaced. However, Yamaha do not sell each piece individually. Go to a reputable motorcycle shop do repair and they should be able to sell you the o-ring for under a buck. That's what I did and thought I share.
  • Birdy426
Posted March 22, 2009 - 09:35 PM
If the shop you go to doesn't have it, they can order it from Sudco.
  • gator4life108
Posted March 23, 2009 - 07:23 PM
quick question on the parts diagram ....what is part number 39......i have it on my carb but no idea what its for...it looks like a knob.....
Thanks,
  • Dan250
Posted March 23, 2009 - 08:32 PM
That would be the knob to adjust your idle speed.
