Oil Cleaner O Ring issue
3 replies to this topic
  • clutchless
Posted March 21, 2009 - 01:06 PM
What would the end result be if you ran a 2006 YZ 450 without the O Ring on part number 4 in the linked picture?
http://shop.thumpert...2006&model=7090
What would fail?
Top End? Valves? Bottom End?
What would you look to replace if this happend?
Posted March 21, 2009 - 03:15 PM
If there was no noticeable oil leak, nothing. That passage leads to the top end and trans oil feeds, and if the O-ring leaked badly enough to cause a danger to the engine, there would be oil all over the right side of the engine. If it just leaked a little, it's nothing to sweat.
  • clutchless
Posted March 21, 2009 - 03:20 PM
noted.
so leaving this O Ring out and not having any oil leak probably wouldn't cause the top end to grenade unless all the oil leaked out.
if the oil did leak out and the top end blew, would there be damage to the bottom end as well?
Posted March 21, 2009 - 07:47 PM
There could be, it just depends. The passage sealed by that O-ring is the upper of two branches of the oiling system that are both fed from the oil filter. A significant loss of pressure on either side would drop pressure throughout the entire circuit, but as I said, it would take a really massive leak to cause a pressure loss.
It wouldn't take a very big one to drain the tank in a couple hours, though.
