426 tick tick tick engine help? pics added
37 replies to this topic
  • Brraaaap Mom
Posted March 31, 2009 - 05:20 PM
#21
Gray, Help...anyone
Tore in a bit deeper, to replace the oil pump. in the process I removed the oil strainer and found it was colapsed, and clogged with the fiberous material that I'm told is left behind from gaskets, shop towels etc. I'm thinking i've found the reason I was not getting oil returning to the sump?
Thoughts?
  • Ztard
Posted March 31, 2009 - 05:22 PM
#22
oops. that was me posting above looks like the wife was still logged in
Posted March 31, 2009 - 06:20 PM
#23
Which oil strainer?
  • Ztard
Posted March 31, 2009 - 06:26 PM
#24
Which oil strainer?
Behind the skid plate in the front. Below the frame drain bolt...If you remember I had another thread a year ago "look what I found in my oil strainer" The seen is no longer a tube...looks more like a squashed pop can
I have not yet got to the oil pump, I need a clutch holding tool
Posted March 31, 2009 - 06:30 PM
#25
That's the feed oil strainer, and yes, that kind of thing could definitely cause an oiling problem.
  • Ztard
Posted March 31, 2009 - 06:36 PM
#26
So I need to clean this strainer every oil change? I'm starting to get paranoid. I do oil changes every 2 track days= 4, 5 hours. But I've only cleaned this strainer twice since i bought the bike......how much more of this material could be in the engine at this point? Is there a better way to clean this junk out?
I still plan on replacing the oil pump at this point.
Posted March 31, 2009 - 07:28 PM
#27
You shouldn't have to clean it ever, really. But now you know why such a big deal is made about cleanliness when working on your engine, and why the manuals all advise "lint-free" wiping materials.
Sound like you may want to flush the oil tank.
  • Ztard
Posted April 01, 2009 - 03:31 AM
#28
Any tips on this process. Again thanks your insight is invaluble.:thumbsup:
Posted April 01, 2009 - 07:26 AM
#29
Remove all oil lines, plug it and fill it with Simple Green and water at 50/50, and let it soak. Lay it on it's side and run the wand of a pressure washer up into it and let fly for a while. Then fill it with alcohol to eliminate the water, then with ATF. Let the ATF soak a while, then drain it and let it drip thoroughly out for several hours.
  • Ztard
Posted April 02, 2009 - 03:24 PM
#30
Finally got around to removing the oil pump. Yes I plan on replacing it at this point, but what about the gouge in the case??? Should I be concerned?
Posted April 02, 2009 - 04:02 PM
#31
The gouge in the case is not ideal, but that's the return pump, so you should be alright. File or sand away any burrs that stand above the machined back surface of the bore.
  • Ztard
Posted April 02, 2009 - 04:05 PM
#32
Thanks, will do. :thumbsup:
  • Brraaaap Mom
Posted April 18, 2009 - 02:36 PM
#33
All back together. The bike makes good power, but still ticks more than I would like???
  • Ztard
Posted April 18, 2009 - 02:38 PM
#34
Again oops. looks like the wife has been on the thumpette forum again. The above post was me.
  • tntmo
Posted April 18, 2009 - 02:52 PM
#35
How much did it cost for the head repair?
  • Ztard
Posted April 18, 2009 - 03:00 PM
#36
$285 including reshiming and grinding valve seats....basic head rework. Not to mention the oil pump!!!!!$100.
  • yzf426f
Posted April 24, 2009 - 12:06 AM
#37
how much is a new head gonna set u back?
  • Ztard
Posted April 24, 2009 - 09:18 AM
#38
I did not buy a new head, i got the original fixed. OEM $700
  • Hot  113 replies
  • On Yesterday, 06:20 PM
  • 10 replies
  • 9 replies
