Steering damper comparison; pros/cons ?
17 replies to this topic
  • Chaindrive
Posted February 22, 2003 - 07:10 AM
I know Scotts makes a very popular unit. I am wondering how the W.E.R. compares.
I honestly like the idea of the lower location, no special triple clamp, and ease of transfer to another bike that the WER offers, but there must be other considerations?
Like ease of adjustment, durability, effectiveness, value (how big a difference do they make?), etc. What experiences do you guys have?
  • hoov165x
Posted February 22, 2003 - 11:47 AM
I have a WER but just bought a Scotts. I have used the WER on numerous bikes since 1996 and it has worked OK. I am, however, sick of butchering my front # plate. The reason I switched is it just doesn't work on the '03 YZF, as the frame mount is too close to center of the steering head and is just plain designed wrong. OK, so as you turn the bars to the right it damps as it is supposed to, because the damper arm is on the left side as is the frame mount. The damper, because it is mounted forward of the steering head moves to the right as well; away from the frame mount. You get goood damper action. In other words it is a straight pull, 1:1+. If you turn the bars to the left however, the arm is pushed, and as the arm is pushed the damper itself turns to the left and slows the rate at which the arm is pushed. This is hard to describe but it is a basic geometric problem. At one point the arm actually stops moving completely- after about only 1 inch of so of handlebar movement. So what you essentially end up with is a one way damper. Now all I have to do is figure out how to mod a pad to fit over the Scotts.
  • Hick
Posted February 22, 2003 - 04:51 PM
Mount it backwards and run a crossbar.
  • RedBaron
Posted February 22, 2003 - 05:28 PM
Will a scott's fit on the stock WR450 bars? My dealer just said i had to order new bars with a higher crossbar.
  • Hick
Posted February 22, 2003 - 07:22 PM
I used to know off the top of my head exactly how much bar-to-crossbar clearance you needed to run a Scott's damper, backwards. I've forgotten what that # was but I wanna say 42 mm.
I don't know that a Scott's will clear any crossbar if mounted in the forward or "normal" position unless you bend the crossbar, and bending one that is welded to the rest of the bar, like the stock WR bars, doesn't sound like a good idea.
Having said all that, if you are willing to shell out the $$ for a damper you should replace the bars anyway. It is only a matter of time before they get bent.
Just my two cents.
  • jetdave
Posted February 22, 2003 - 08:19 PM
I like my GPR :D It bolts on to the stock clamps and fits underneath my Demanari handle bar with curved up brace. I don't want to ride without it :)
  • blitzer544
Posted February 23, 2003 - 09:54 AM
I have a GPR and love it..If you ride trails with rocks it makes all the difference.
  • PumpkinHumper
Posted February 23, 2003 - 11:10 AM
Renthal makes a bar for Scotts that has the cross bar pre curved to clear the dampner.
  • HaremScarem
Posted February 23, 2003 - 01:06 PM
I have the Scott's installed under Renthal "Jimmy Button" Highs.
The tech at Scott's said "The Buttons are the only Renthals that will fit without bending the crossbar".
I Now wish I spent the extra cash and picked up the Pro Tapers with a Scott's clamp.
  • YAMAKAZE
Posted February 23, 2003 - 01:31 PM
Why go with the inferior WER when you can have one of these configurations.
http://www.scottsper...photos2/396.jpg
http://www.scottsper...photos2/397.jpg
http://www.scottsper...photos2/398.jpg
http://www.scottsper...photos2/399.jpg
Any Config you could want at Scotts...They even do custom configs for Enduro guys...
Bonzai :)
  • WR450F_4600FT
Posted February 23, 2003 - 10:01 PM
I've never got head shake on my Yamahas, so I really don't see the need for a damper untill I have a problem. I have had the need for a damper many times on a CR 500. I would never ride a CR very hard over rough terrain without one!!!
  • sabin
Posted February 23, 2003 - 10:40 PM
Have you ever ridden offroad bike with damper?
  • Chaindrive
Posted February 24, 2003 - 05:54 AM
No, I haven't, Sabin. Which is a very good point after reading all this good input (thanks guys!). I can't think of anyone I know who has one either, or I would sure be asking to ride their bike once. It is a very expensive accessory, which is why I wanted to research the options and benefits well.
Nice pics, Yamakaze, thanks!. My concern for my WR is to not block or have to remove my speedometer or high beam indicator or headlight (kinda crowded up there). I currently have TAG 2's in CR Double-Hi bend (no crossbar). They are mounted with low-dollar 1 1/8" adapters on the stock triple clamp.
Incidently, does GPR have a website providing info and pics? I want to be thorough, and this is a new one to me.
  • sabin
Posted February 24, 2003 - 10:19 AM
Chaindrive, I was thinking the same way like you. Now I know that this are the best money spend so far for my bike, and even better - it is for all my future bikes.
  • ^SQUID^_Thumper
Posted February 24, 2003 - 11:09 AM
I would recommend the SCOTTS damper, and the DirtTricks mounting kit. Here's how I mounted mine :) DirtTricks now has a mounting kit for Yamaha's.
<<< PIC >>>
  • ekemner
Posted February 24, 2003 - 02:29 PM
Hey if you want I can email a photo of my YZ450. I have the Scotts mounted on it with the Renthal Bars with the Scotts bend. It is a very clean looking setup but I think now that I have the Scotts mounted by reversing the arm that the stock bars may work fine. If you would like a photo then send me your email address to cmelkfarm@aol.com and I will send you a photo as I do not know how to list photos here.
Eric
  • YZ400Court
Posted February 24, 2003 - 04:25 PM
Here is a link to GPR. http://www.gpr-products.com/ At one time they had a policy of full refund if you did not like it.
  • Dodger
Posted February 24, 2003 - 04:55 PM
Do youself a favor if your shelling out the money, and get the Scott's. Tried and true.......
Dodger :D :)
