how do i know the motor is getting coolant?
8 replies to this topic
  • silmo20
Posted March 20, 2009 - 07:00 PM
i've seen many threads about headers getting red hot, mine does the same. within a minute to two minutes it glowing and the radiator and hoses are really hot to touch. i know the glowing is normal to a certain degree, but i think this is too much. its a 2001 yz426. please keep it simple, don't know much about these things.
Posted March 20, 2009 - 09:50 PM
If the top of the radiators get hot, and warm air blows through the srouds as you ride, it's circulating.
  • Tomok
Posted March 21, 2009 - 03:29 AM
If you leave your bike running on the stand or just not moving at all, a four stroke header is going to glow. I would try to limit this as much as possible.
  • ZMoney520
Posted March 21, 2009 - 05:10 PM
while the bike is cold, crank it and take off the radiator cap. You will see the antifreeze moving across the opening. Just do this for a few seconds. Don't do it while it is hot. Make sure you put the cap back on.
  • jjj109
Posted March 21, 2009 - 06:37 PM
read your manual. it says not to let bike sit and run for more then several mins cause it will over heat. high comp, aggresive cam, with retarted ignition timing when idling doesnt mate well just idling. a engine like YZF's have would need a fan for the radiators to keep the bike from over heating just from sitting and idling .
  • silmo20
Posted March 22, 2009 - 04:55 PM
ok, i'll try that. thanks a lot.
  • travisn
Posted March 27, 2009 - 09:00 PM
How about knowing when its too hot? I was riding a really slow/muddy single track the other week and it kept gassing out coolant, which is normal, but there has to be a limit some where between losing too much coolant and getting too hot.
I have since installed an over flow tank, but I still get worried. there is no room what so ever in the budget for a rebuild. maybe a mechanical temp gauge?
  • 426 NOOB
Posted March 27, 2009 - 10:31 PM
Pro circuit makes stick on temperature strips that you can stick to your rads and cylinder to keep an eye on engine temps. I think they are pretty inexpensive too.
  • stk0308
Posted March 28, 2009 - 09:03 AM
They're a great idea. But a little hard to check while rolling down the trail :thumbsup:
  • Hot  38 replies
  • Hot  28 replies
  • 10 replies
  • On January 15, 2017
  • Hot  50 replies
