Case cover removal
4 replies to this topic
  • blbusenbark
Posted March 19, 2009 - 09:12 AM
I have a small hole in the cover of my left side case (shifter side) and was having a problem with the removal. I took out ever bolt and the torqe gear. Any body know what I missed?
  • matt4x4
Posted March 19, 2009 - 11:44 AM
depends where the hole is - the left side does not have a full cover like the right side does - it's only partial, if it's outside of the area that covers the stator, then it's actually your engine/transmission case that has the hole in it and you'll need to split your motor completely to remove the case half.
  • Dav810
Posted March 19, 2009 - 05:26 PM
On the part of the cover that covers the starter, there is a cap over it with a little mark on the top if it. Pull that off and the starter clutch will fall out. There is a bolt behind there.
  • DrBosa
Posted March 23, 2009 - 03:13 AM
Is the problem you can't get the cover off, or what? If so, Dav810 above has a point. It is easy to miss the case bolt in the idler gear cavity.
  • Dav810
Posted March 23, 2009 - 06:26 PM
This is the bolt hole I was talking about. I had to change the cover gasket so I took this picture to show you the hidden bolt.
