Headlight keeps burning out
1 reply to this topic
  • proth
Posted March 18, 2009 - 05:19 PM
I have a '06 WR450 and am having a problem with the headlight. The bulb was burned out so I replaced it. It worked when at idle, but quickly burned out when I went for a ride around the block. I checked the voltage going to the light and it was ~ 15V at idle, but goes up above 20V with engine rpms. I'm guessing I have a problem with the regulator? Anyone had a similar issue?
  • GCannon
Posted March 18, 2009 - 09:25 PM
Search this forum for = Voltage Regulator!
Too many good posts to list for you here!
Check AC voltage at the Head light plug if > 14.5 when motor is reved then Voltage Regulator is suspect. You Should check for bad ground and other bad connections before replacing regulator.
