WR450 Throttle Stop
4 replies to this topic
  • Roger_H
Posted February 21, 2003 - 04:50 AM
Are there any negative effects from cutting the throttle stop screw too short? I cut way more than 11MM off of mine.
Also, found a neat way to get a little more air in the airbox. The black cover on the right side of the airbox can be removed by drilling out two rivits. Once it is off drill several 1 inch holes in the air box. You enduro guys might not want to do this because the chance of getting more crud in the airbox but for a dual sporter like me it might help.
  • yamaharichey
Posted February 21, 2003 - 10:57 AM
The only possibility that I know of is it might let the slide come up so high that it will get stuck, I don't know if that has really happened to anyone though.
  • WR450F_RDR
Posted February 21, 2003 - 01:17 PM
The other negative possiblility I heard of is overreving the motor.
  • wr250rr
Posted February 21, 2003 - 01:36 PM
The TPS may send inaccurate info to the brain
  • Motorod
Posted February 21, 2003 - 04:51 PM
Mine is too short, and it does not get stuck. I have not had a chance to ride, except for the driveway so I don't know about other problems as others have stated here. I have heard the same storys though.
