back firing and won't idle 02wr 426
8 replies to this topic
  • comp182
Posted August 11, 2002 - 02:22 PM
So, i was riding today up to around 12000 ft with no problem. Came back down and went back up another pass and about 3/4 of the way I had to stop for a 4x4 and the bike seemed to load up and would not idle. So a pulled the Hot start and got it to start but was still running bad and finally died. So after kicking and kicking I just did the old ride it down hill and get it started that way. This worked but still will not Idle and seems to want to back fire slightly. I don't feel that it is jetting because I have been on this ride several times with no problem. Also I got home and Put in new Plug in and Still does the same thing. Any Ideas?????
  • jonesy1
Posted August 11, 2002 - 03:04 PM
Check the carb slide? Do a search on carb slide, there have been a few discussions on here about similar problems, some had cracked carb slides. Just a thought.
  • Bamster
Posted August 11, 2002 - 03:34 PM
Could it just be dirt in the carb?
  • skthom2320
Posted August 12, 2002 - 05:19 AM
I would clean the carb and all jets thoroughly. Make sure and inspect the carb slide for cracks (don't put it back in upside down - it's easy to do).
  • comp182
Posted August 12, 2002 - 05:53 AM
Thanks for the info I will clean the carb and look for a crack in the slide plate to night.
  • Hick
Posted August 12, 2002 - 08:01 AM
Make sure you check the air jets under the carb bell, if your pilot air gets obstructed the bike won't idle.
  • comp182
Posted August 12, 2002 - 01:44 PM
OK here is the deal I took the carb off looked at the slide plates and there is no crack. However I took the float cover off and noticed that there is NO Pilot Screw. I Guess I am to assume that the Dealer left it out or it never came from the factory with one???? And I know what you are thinking and no it was not in the cover or anywhere esle. So now my question is that I have 400 miles on this thing and it has never had a pilot screw in it. So is this my problem or is it something else????
  • tk421
Posted August 12, 2002 - 02:05 PM
It came with a pilot screw, just vibrated out is all. If you turn it 3 or more turns you run a good chance of it walking out. Better then to go up a size on the pj and one turn on the ps.
  • comp182
Posted August 12, 2002 - 02:41 PM
yep, your right it did fall out. Thanks for all your help. Well it looks like I have no excuse but to do the BK Mod now.
