Oil leak help
5 replies to this topic
  • Brown713
Posted March 17, 2009 - 07:28 AM
Hey everyone........new to the site......I have an oil leak from behind the front sprocket....On my 06 YZ 450......I have replaced the 2 seals 3 times & it just keeps on leaking a slow but consistant leak......Can anyone tell me what to do to stop this leak??? Thanks!!!!
Posted March 17, 2009 - 07:37 AM
The steel collar the seal runs on may have a groove worn in it. If this is the case, the collar needs to be replaced. There is also an O-ring that seals between the collar and the shaft. It's not usually at fault, but it's also really cheap.
  • matt4x4
Posted March 18, 2009 - 03:42 AM
replace all 3 parts as Grey said also check for play (side to side/up/down) on the output shaft - if you have play it's a worn bearing which can be culprit too.
  • Brown713
Posted March 20, 2009 - 06:13 AM
Thanks guy!! I will check into it...
  • madtaff
Posted March 06, 2010 - 12:39 PM
maybe a silly question the shaft seal can it be replaced as easy as it looks also does the steel collar come out without a fight ? cant seem to find part numbers mine is also on an 06 450f
Posted March 07, 2010 - 01:26 PM
The seal is easy, but the collar can be a little stubborn. It tends to stick to the O-ring that seals it to the shaft. Once the sprocket is removed, a tap or two on the end of the shaft with a mallet or wood block will bump the shaft inward enough to snap it free of the O-ring, then you can grab it with a pair of "channel locks" and twist it out. Fish the O-ring out with a pick.
The seal, collar and O-ring are items 28, 29, and 30 on the transmission page of the fiche.
http://shop.thumpert...2006&model=7090
  • 0 replies
  • Hot  28 replies
  • 9 replies
Motocross
  • Hot  491 replies
