Why does my rear light keep blowing the bulb?
6 replies to this topic
  • Lennie
Posted March 15, 2009 - 11:35 PM
I dont know why my 04 Wr450 keeps blowing the bulb in the rear light, the tail light bulb lasts about one - two hours and the brake light lasts about five hours then blows.
Is there something that I can check like places where the wires are well known to get damaged? How much power should I be getting to the rear light?
I ride on the roads, dirt and supermoto so need a rear light to be legal !!! Changing the bulb every hour is crap !!! Help please. :) :banghead:
  • doctorchopper
Posted March 16, 2009 - 01:43 AM
My bulbs are blowing regularly as well, it turns out my voltage regulator/rectifier is toast. There should be around 12 volt ac, but with the revs up i was getting up to 24 v ac.
  • William1
Posted March 16, 2009 - 03:18 AM
Could also be vibration or a bad ground. These are common causes of blown bulbs on a AC system.
  • Lennie
Posted March 16, 2009 - 05:22 AM
I had a new voltage regulator / rectifier not too long ago and this didnt solve the problem. Also the headlight has had the same bulb in for over a year.
  • William1
Posted March 16, 2009 - 05:46 AM
Check the ground connect for the tail light. As I said ealier, it could well be a vibration issue. A change to a LED replacement may be the cure assuming the ground is good.
  • doctorchopper
Posted March 16, 2009 - 10:12 AM
With it being an AC system will it be grounded?
  • doctorchopper
Posted March 16, 2009 - 11:00 AM
Just looked at the wiring diagram and yes it does go to ground.The wire Marked B, so i'd say black or brown
