Simple gearing question for 07 WR450
4 replies to this topic
  • AFJ7732W
Posted March 14, 2009 - 06:34 PM
I apoligise if this is a dumb question.....
I am currently running 13/50. I don't want to put a little 12 up front. I want to go up 3 teeth on the rear. The only one I have found is aluminum. I want steel if at all possible. Is a steel 53 available? From whom? How many links will I have to add? Will the chain guide need to be modified? Replaced?
Thank You, RJ.
  • KennyMc
Posted March 14, 2009 - 09:09 PM
Iron Man sprockets make a 53.:) Tell them you are a member of the BRC and you should get a 10% discount.
Talk to them about the chain length. They have chain / sprocket combos.
http://www.dirttrick...g_sprockets.htm
  • chevytrkn1
Posted March 15, 2009 - 05:34 AM
I added two to my back sprocket and thats Maximum on chain length
  • AFJ7732W
Posted March 16, 2009 - 08:07 AM
Ken, the Ironman looks to be the answer. Light weight and steel to boot. It is just a bit on the pricey side, but you usually get what you pay for.
But for now, until I wear out my oem chain, I might try a Sunstar 52.
Thanks guys.
RJ
  • kingquad450
Posted April 02, 2009 - 03:46 PM
What did you ever find out about the chain guide?
