Preliminary data on woodruff key failures
234 replies to this topic
  • allinson
Posted April 16, 2003 - 05:22 PM
Before reading this information, keep in mind, I am not a statistician. Also I wish the test group had more numbers in it to validate the information. Despite the small response I noticed some interesting preliminary data. In other words, take this for what it's worth.
Here is the skinney
Production (serial numbers)
From 1091 to 1766 = 100% of the failures in the study group. No failures were reported from 0-1090 or from 1777 or above. The 1766 appears to be a spike in the data. The next highest failure was at 1321.
From 1091 to 1286 = 77.7%
I also noted after reviewing the posts on the bikes that have not failed that the 1000 and above were the first ones delivered to the dealers. Those who received the second shipment of bikes were more like to receive one from 0-1000. With the limited data received, the failure is somewhat related to production number.
Miles to Failure
Of the reported data, 0-130 miles = 100% of the failures. 0-50 miles=55.6% of the failures and 51-100 miles =44.4% of the failures. Based on the limited data, it appears the more miles on your bike, the less likely you will have a failure.
Thanks to all that responded to the post with the information.
RIDE ON
  • Motorod
Posted February 19, 2003 - 06:01 PM
From my past experience, it takes about 30 in a group down the production line to make a prediction of what is to happen in the future. What you have right now is the best we at TT have. Thanks for the effort! I think the engine numbers would tell a better story. Frame numbers can be too far removed from the point of assembly of the shaft, fly wheel, and the torque of the nut. JMHO
  • Number82
Posted February 19, 2003 - 06:02 PM
Good analysis! FWIW, I haven't posted in either category yet as I've only run 1.7 miles on the clock due to weather (1.7 glorious miles). Mine is in the 670-something range and came in 2/10/03 in Baltimore, MD. It came with the add-in page and stickers in the manual. No clue on current flywheel nut torque but will check soon.
-g
  • Alabama_Rider
Posted February 19, 2003 - 06:17 PM
Excellent work! This is what Yamaha should be doing. Your data suggest a manufacturing defect and not a design problem. Thats actually good news. <ul type="square"> "Production (serial numbers)
From 1091 to 1766 = 100% of the failures in the study group. No failures were reported from 0-1090 or from 1777 or above." [/list] It is interesting that the first batch shipped started with the 1000+ serial numbers, and all failures occured in that batch. Perhaps Yamaha knows they had a production problem, and fixed it before the second batch? This is great work. :)Please continue. Hopefully you will be able to give this data to Yamaha, and get feedback as to what they are doing, if anything, with it..... For those unfortunate to have a serial number in the 1091 to 1766 run, you can expect to have problems... :) Call your dealer.
  • foursmoke
Posted February 19, 2003 - 06:33 PM
This info makes me feel a little better about MY purchase for I have 0 miles on mine with prod.# 0602.I did however remove my ignition cover last night & checked torque.It was 47 spot on. :D
03 WR450FR-picked up 2/3/03. Works connection alum. frame guards. :)
  • WR450F_4600FT
Posted February 19, 2003 - 08:38 PM
Engine # is J314E-002376 to add to data base.
Good job all, way to show power in numbers. This site has helped me feel much more confident about this problem since Yamaha is setting on thier hands about a problem they know they have.
  • Wrench
Posted February 20, 2003 - 01:56 AM
Loose rotor nut, no failure frame # 0413 engine #1168
  • adamwagar
Posted February 20, 2003 - 04:30 AM
The dedicated members of ThumperTalk will solve this problem for Yamaha. I think Yamaha should kick in some cash for consulting fees...LOL... :)
  • MrTwister
Posted February 23, 2003 - 11:39 AM
in the case of 1000+ being shipped first, then 0-1000 shipped later its far more likely that the first ones built were at the back of the warehouse and too hard to get to! they just the ones at the front first.
cheers
Lachy
  • foursmoke
Posted February 24, 2003 - 06:41 PM
Does anybody think Yamaha would be willing to repair a woodruff key failure at no charge after the 30 day warranty has elapsed?Just hopeing because it will be April before mine sees the woods.
03 WR450F-grey wire,works connection alum. frame guards
  • BEAN329
Posted February 24, 2003 - 07:31 PM
here's my 2 cents, point one check flywheel torque first - before starting. point 2 the manual states on page 3-2 after breakin check rotor nut. Now since nothing has come through my yamaha dealer as far as problem with the woodruff key, which i trust very much, at this point in time i think that yamaha does not consider the current issues a problem. once again part of the problem sounds like RTFM. Final point - I did not have to do any type of mods on my 98 XR 400 but this WR 450 is a totally different animal. These new machines are high tech and need to be treated a bit differently. Do not misunderstand my final point, I plan on racing this bike a lot harder than my XR 400, thats why I bought it, I just mean that until we figure out the ins and outs of these new bikes some problems will crop up, and that it may not be a Yamaha problem its a uninformed user problem. RTFM RTFM
  • Alabama_Rider
Posted February 24, 2003 - 08:22 PM
When you pay $6,000+ for a new bike you expect a machine with no design or production defects. I hope you don't expect less. My 02 Honda XR650L ran like a swiss clock without ever a problem, and I expect the same from my Yamaha. The XRL has electric start and I used it everyday. No-one ever had a problem with it or a "Woodruff key". This problem is Yamaha's and we should expect them to fix it or they will lose their market share back to Honda.
  • adamwagar
Posted February 25, 2003 - 05:18 AM
"may not be a Yamaha problem its a uninformed user problem"
I'm informed enough to know this is a Yamaha problem. They will fix it. Wish they'd hurry up.
  • BEAN329
Posted February 25, 2003 - 05:43 AM
hey alabama rider, hey adamwagar, did you check your flywheel torque yet, have you had a key prob ??.
And just another thought, wait til people start removing the neutral switch and the clutch lever switch, and start using the E button IN gear. That small key doesn't have a chance if the flywheel torque is low.
  • adamwagar
Posted February 25, 2003 - 07:21 AM
I'm in Northern Michigan, 8 below zero and three feet of snow. Wont be riding for at least a month. So, I have time to wait for the official TSB from Yamaha.
Like I've said before, I don't want to replace the crank because of a botched "Over the phone Fix".
  • Alabama_Rider
Posted February 25, 2003 - 04:30 PM
Exactly, <ul type="square"> "That small key doesn't have a chance if the flywheel torque is low." [/list] I believe the key design is too small. Yamaha will have to redesign to increase its size, which would be an expensive recall for Yamaha. Perhaps that is the reason we haven't heard from them. Yes I verified torgue at dealer and haven't had a failure, but am very careful when starting to NEVER touch the throttle.
  • BEAN329
Posted February 25, 2003 - 04:49 PM
I was talking to a friend today about E buttons in general and he said that KTM's manual states that there E button is to used after the engine is warm. Do you know it thats true.
  • Rainman_WFO
Posted February 25, 2003 - 07:38 PM
Allinson -
Just a note to report that my #0996 WR450 just sheared the key after 54 miles (second ride).
If the dealer balks at doing the repairs, how do I hold the rotor while re-torqueing the nut after I get a new key ?? Its been 45 days since receipt of my bike, so I suspect the dealer will whine.
Rainman :)
  • gsxrguy
Posted February 25, 2003 - 09:31 PM
ser#1243 canadian model 17 kilometers, checked key torque with snapon click type torque wrench,set at 45foot lbs to loosen. It did not click.retorque to 61 foot lbs as per manual update. noted that by looking backwards thought back of page orginal speck is 50 lbs.
  • Wrench
Posted February 26, 2003 - 02:14 AM
Rainman,
When you pull the cover you will see the answer to your question, there is a built in hex on the rotor that uses a 15/16 wrench. It's shown in the manual pages 4-78 and 4-81 you should lap the rotor in just takes minutes.
