Help with gearing setup 08 YZ450
3 replies to this topic
  • DTYZ426
Posted March 12, 2009 - 09:45 PM
Picked up my new 08 YZ450 this past weekend, got to ride it a bit. I am in the process of setting it up to suit me. It was suggested to change the gearing to a 12/51 for trail riding. Seem a bit low. Also, I will be riding some motocross with this bike. What gearing should I start out with? A Rekluse Pro has already been installed if this matters as to the choice of gearing.
Posted March 13, 2009 - 06:45 AM
I'd suggest you try it as it is first, and see if there's anything about the way it's geared that you don't like before I spent on sprockets. I ran mine stock until the sprockets finally wore enough to merit replacement, and it was fine that way. You're using a Rekluse, so the bike will be even more flexible as to gearing at low speeds.
Wait and see.
  • Wiz636
Posted March 13, 2009 - 07:42 AM
Forget about the 12/51...that is way too low and running a 12t front sprocket has it's own problems as well like excessive wear on the chain slider.
As Gray says, since you have the Rekluse already you may not even feel a need for a gearing change.
I would however dump the stock chain and replace it with a quality chain like a Regina ORN6. The stocker is so cheap that it will stretch out of spec almost immediately and begin destroying your sprockets.
  • DTYZ426
Posted March 13, 2009 - 08:19 PM
thanks for the insight. Just received the ORN6 today, best chain on the market IMHO, been running one on my YZ426 for the last year and it's still like new. I will wait on the gearing change until I wear out the originals. :)
  • Hot  28 replies
  • Hot  50 replies
