New 08- hard starting
10 replies to this topic
  • JWW
Posted March 12, 2009 - 07:22 PM
I bought a new 08 WR450 last weekend.I havent taken it out yet but I have fired it up in the garage a couple of times. I know these things are dogs before opening them up but Im having a hard time getting it started. I have better luck get it going with the kickstarter. Is this also normal when new?
I have all the parts to uncork and rejet but I am going to do a break in ride Saturday. I want to be sure there are no warranty issues before I tear into it.
  • calwestjeff
Posted March 12, 2009 - 08:03 PM
Hey, Mr. Jeff
My 08 250f was the same way at first. After first ride and opening exaust and adj. fuel screw, it now starts right up with the e- start no problem. Remember no throttle or you will flood it instantly, then very hard to start!
Great bike, you will love it!!
Jeff
  • fpvf6
Posted March 12, 2009 - 09:42 PM
They are all like that untill they are run-in. It will loosen up after 100klms or so and be sweet as.
  • JSanfilippo
Posted March 12, 2009 - 10:03 PM
My previous bike had a kick ass e-starter. It had to, it was the only way to start it unless you count bumpstarting.
The e-start on the WR 450f is kind of a joke. It has 2 dead revolutions (with no spark) and it sparks on the third. There is a wire modification you can do that it'll make it start with one starter revolution but I think it puts more strain on the starter.
It should kick in 1 or 2 kicks even stock. Thats one thing that surprised me about my bike when I first got it. It ain't no damn XR when it comes to starting :)
  • TheCape
Posted March 13, 2009 - 10:33 AM
I have the same issue. I just picked up my 09 WR450 and it almost killed the batt. befor it finaly fired off. This is my first Yamaha after giving up a KTM 525SX. I must say once I had it running I took off for the hills and after getting use to the diffrences between KTM and Yamaha I can honestly say It will be Yamaha from now on :)
  • JWW
Posted March 14, 2009 - 10:18 PM
Finally got it out today for a 20 mile break in. I had a lot better luck with starting after running a few miles.
After the first couple miles I shut it down to check for leaks or any obvious issues. I couldnt get it e-started so I kicked and it fired right up. I got about another mile down the trail and I heard a ratcheting noise. I looked down and the kicker appeared to be ratcheting forward and back. I pushed it back a little and it stopped. I didnt have any other issues after that.
Should I worry about any damage from the ratcheting kicker? I heard it and stopped with 20-30 seconds.
  • JSanfilippo
Posted March 14, 2009 - 11:49 PM
Not if it happened just once:thumbsup:
Just don't make a habit :banghead: :)
  • sniperjaggi
Posted April 14, 2009 - 07:51 AM
I also have an 08 WR450 that I bought new (last year's model bought in February). I had a 99 WR400 before this one. With my 99 if you touched the throttle even a little bit when kick starting it, it was tough to start. With my new 08 I have to give it a little fuel with starting it or it is tough to start. Just opposit of my 99. I did all of the mods on my 08 once it was broke in, but it didn't matter, it needs a little fuel from the throttle to get it started. It is a lot harder to start if it is really cold. Anyone else had something like this?
  • Regalman
Posted April 14, 2009 - 07:57 AM
When new, mine refused to start when it was really cold.
For mine, when cold I now do a full choke and crank the throttle fully about 3 times then hit the button. It usually tries to fire then dies, then I give it 3 more throttle whacks and it will start.
When hot, I always pull the hotstart and it fires right up. Otherwise it takes more cranking.
  • William1
Posted April 14, 2009 - 08:07 AM
Regalman, you may want to try a larger starter jet. Not uncommon to need a few quick twist O' the wrist but once it catches, it should stay running. A stall like you describe is symptomatic of a too small starter jet.
  • WR450FGreg
Posted April 14, 2009 - 02:21 PM
Not much help.... but for the record my '08 starts easily every time.
Cold: Choke on and crank/kick it with no throttle.
Hot: Hot start lever pulled in and crank/kick it with no throttle.
Greg
