What header pipes will fit on an 03 wr450??
6 replies to this topic
  • 150 Fuelie
Posted March 12, 2009 - 07:15 PM
I just picked up an 03 WR450 with a pretty dinged up header pipe. What years pipes will work on the 03 WR 450 engine??
Also, Does anyone have nice stocker they want to part with??
One more question; If I went with an aftermarket like a powerbomb will it fit with my stock mid pipe?
  • Mrmonk7663
Posted March 12, 2009 - 08:07 PM
I'll have a good 2004 header pipe in a couple weeks...
Mike
  • DrzDasher
Posted March 12, 2009 - 09:09 PM
Take the header and put water in it then put in freezer, should take the dent right out, might have to do it more than once. make sure the dent is under the water line. Hopefully you have a big freezer or your old lady will let you use the kitchen freezer.
  • 150 Fuelie
Posted March 13, 2009 - 06:17 AM
I found the thread about doing this after I posted mine. I'm going to give this a try 1st. Thanks.
  • DrBosa
Posted March 13, 2009 - 07:53 AM
I have a -03 450 and FMF Powerbomb header pipe. Works like a charm.
  • DuneDevil
Posted March 14, 2009 - 06:13 PM
Many people to the freezer trick? I used to do it on my old 2 strokes, but I'm afraid it would take the bend out of the pipe... No issue there?
  • 150 Fuelie
Posted March 15, 2009 - 04:03 PM
The freezer trick worked :)
