munched piston, and cylinder......etc
22 replies to this topic
  • MN_Kevin
Posted February 24, 2003 - 03:51 AM
#21
I say do it yourself, including splitting the cases...
I WHOLEHEARTILY agree.
The first (and only) time I split the cases I imagined a butt-load of transmission gears falling out on the floor. I took the bottom end (1982 YZ250 2 stroke) to a shop and had the mechanic look at it. I had tranny damage. He pointed out some gears he recommended me replacing, which I did. I WAS NOT charged for his 5 minute observation.
To split the case, I WOULD recommend a case splitter though. A homemade one would work...and is what I did use.
Doing your own work instills both pride and confidence in yourself. I have read enough horror stories here on TT about ignorant shop mechanics and outrageous service work bills.
:cool:Doing all your own work is an absolute WIN-WIN Situation!!! :)
  • Hick
Posted February 24, 2003 - 07:06 AM
#22
This isn't necessary for the YZF/WR. Even on a seriously lunched motor they come right apart. I speak from experience. :)
  • Fistfull
Posted February 24, 2003 - 07:45 AM
#23
Here is a link that shows some safety wire tech Safety Wire
It takes practice to do it right ( I've got 10+ years on commercial jets ). A 1/16" cobalt drill bit (to poke the holes with) and .032" safety wire is a good combination. Anything on my bike that has a tendacy to loosen, gets drilled and safetied.
Yamakaze, if you start at the skid plate and end up at the bolt, it will be a stronger safety.
