bike dies when bars are turned hard right....
10 replies to this topic
  • tarlint
Posted March 12, 2009 - 11:27 AM
2000 WR 400 runs great. When at idle, if you turn the bars to the right, at a given point the bike starts to die.......if you turn them all the way, it dies immediately.
I tried changing the kill switch out thinking it was shorting.......still does it. Anyone have any ideas???? I am a fairly new rider with minimal experience troubleshooting this stuff.
Thanks in advance for reading and helping.
  • Charles De Mar
Posted March 12, 2009 - 11:31 AM
I would look at the manual and take of the headlight off and check the wiring. Check your throttle cable too.
  • flyer05
Posted March 12, 2009 - 11:59 AM
I think your decompression cable is to tight. Loosen it up bit.
  • GENE426
Posted March 12, 2009 - 12:00 PM
Got to be cable or wire being pinched
  • tarlint
Posted March 12, 2009 - 12:26 PM
should i just move it to the right and try and loosen the cable.....or do I actually twist the cable harness to loosen that part?
  • mightymart
Posted March 12, 2009 - 12:55 PM
Check that nothing is being stretched ie throttle cable. After I had a fall once on another bike the throttle cables rotated round slighly & started to cut out on full lock.
  • flyer05
Posted March 12, 2009 - 01:02 PM
Yes, move it a little to the right. As you turn right it is opening the decompression release and the engine will die.
Good luck.
  • bluebike1999
Posted March 12, 2009 - 01:46 PM
yep, had that one too...i thought it was the kill switch too
mine did it after i fitted new bars with raisers...decomp lever just getting tension, enough to open it a bit
good luck
  • Frostbite
Posted March 12, 2009 - 03:00 PM
good luck
Add me to the tight decomp club, an easy fix though.
  • OUTERLIMITS
Posted March 12, 2009 - 04:23 PM
I seem to recall the same problem on my 650 right after I put taller bars on. I ended up loosening everything up and moving the kill switch, clutch lever/decomp inboard just a bit and it went away. Never could determine which it was, but same deal right hand turns only going real slow where you really crank the bars over.
  • creeky
Posted March 13, 2009 - 01:45 AM
Had the same problem some time back on my '01 WR400, decomp cable misrouted, turning the bars activated the decomp.
