07 wr exhaust
2 replies to this topic
  • r stene
Posted March 12, 2009 - 10:21 AM
Can anyone tell me if a 08 yz 450 exhaust will fit my 07 wr? Thanks for your help.
  • WR450FGreg
Posted March 12, 2009 - 10:38 AM
Yes it will.
But if you mix/match headers and mufflers you will need to modify the sealing joint between them.
Greg
  • lockheed
Posted March 13, 2009 - 09:36 AM
Actually I believe the diameter of the muffler inlet on the yz and wr are exactly the same. The yz has a larger diameter header and therefore uses a different size seal than the wr (outside dia of both seals are the same - inside dia larger on the yz ). I have an 07 wr and used stock header with shorty 08 yz muffler w/pmb insert - now have complete 08 yz system. works and sounds great.
Ed
