wr 400 '00 trouble.....
5 replies to this topic
  • maxwr400f
Posted March 10, 2009 - 04:48 AM
hi to all
excuse for my enghish( i am italian)
my wr have had completly replaced the engine 1year ago.... and every things went ok for 6 mounts.... after i bought a cr250honda and wr stopped in garage.
i used it a time...... all ok
second and third append:
at first run engine doesnt go up in rotation and bangs from exaust.... after goes very good for 10 minutes and again problems... and so on for 3/4 times and after goes ok....
i clean carburetor but my idea is about CDI or TPS or neutral sensor.
have anybody here had similar experience....
please help...
  • stevenacarter77
Posted March 10, 2009 - 05:32 AM
try cleaning out your fuel tank and use new fuel make sure tank flows fuel, you said it was parked for awhile, so this would be frist on my list.
  • maxwr400f
Posted March 10, 2009 - 07:33 AM
but the tank was empty along the stop period and obviously i felt it up with new fuel.
but now i am remembering a friend who has had troubles by the hose cap...
i'll check.
any else ideas, anyway?
  • maxwr400f
Posted March 10, 2009 - 07:37 AM
i left the tank empty during the stop period and i fill it up with new fuel.
but you meke me remenber a friend who had troubles with the hole cap.
i'll check it.
any ideas else, anyway?
  • stevenacarter77
Posted March 10, 2009 - 09:17 AM
see what color your spark is should be blue/ not red or yellow also run it 15 min then shut off and see if the coil is to hot to hold on to if so replace. its breaking down.
  • maxwr400f
Posted March 11, 2009 - 01:28 AM
do you think that coil gives alternated problems?
because, as told, the engine goes some time very well and after arrives more or less not over 3000/4000 rpm.
i hope anyway that coil is my problem.
