How can I tell what weight fork springs I have?
5 replies to this topic
  • fastmonstr
Posted August 08, 2002 - 09:10 PM
Where do you measure?
[ August 08, 2002: Message edited by: fastmonstr ]
  • fastmonstr
Posted August 09, 2002 - 12:06 PM
Do you measure the diameter on one coil?
  • fastmonstr
Posted August 12, 2002 - 06:58 AM
Anybody?
  • 98yz
Posted August 12, 2002 - 07:30 AM
Are you looking for what the spring rate is? As in .42 kg/mm .40 kg/mm etc?
[ August 12, 2002: Message edited by: 98yz ]
  • fastmonstr
Posted August 12, 2002 - 10:24 AM
Thats correct. I should have worded it different.
Is there a way to tell what the spring rate is without a spring tester?
  • 98yz
Posted August 13, 2002 - 06:42 AM
not that I am aware of. Well sometimes the factory puts a colored dot on the top of the first coil of the spring and then you have to look in the manual. Have the springs been changed?
