So disappointed in 2008 450
23 replies to this topic
  • jasonbla
Posted March 08, 2009 - 10:33 PM
I can't believe I would ever say this of a 450 but the 08 motor is weak. It's the most boring motor I've ever rode. It had the feel of a 125 (all top end) I never needed more then my 05 crf450 could give and I loved the spread of power. I ride the desert in Utah and I found myself having to shift a ton on the yz. The whole bike felt so vanilla:banghead: . The suspension was a tragedy but thats due to the clickers. I'm thinking of selling or trading and getting a kx. What do you guys think? can you pump character into this bike cheaply? or should I just get the kawi? also what clicker settings do you run? i'm fast amatuer 175lbs desert. Thanks guys
  • Slinkyman16
Posted March 08, 2009 - 11:14 PM
well thats a first..
The stock muffler sucks and mellows down the motor alot. get an aftermarket exhaust that will open things up a bit.
suspension.. shouldnt be a problem cause the kyb sss setup is one of the best factory setups but its set up for mx.. what exactly is it doing that u dont like? is it to hard? to soft? need more info..
the exhaust should do it.. if it dosnt u can always add a cam or hc pistion..
  • PAdaytonaman
Posted March 09, 2009 - 04:58 AM
Just let him sell it
  • geshields
Posted March 09, 2009 - 05:28 AM
Get an aftermarket exhaust. I personally like the DR. D.
The suspension is setup for a 210lb rider in the front and a 180 lb rider in the back. Changing out the springs would help....
  • William1
Posted March 09, 2009 - 06:03 AM
I suspect it is not much as down on power but the lack of 'kick' at lower rpms. Many percieve an engine with a nice, smooth hp/torque curve to be weak. You can make a few mods to 'interrupt' the smooth flow of power which in turn will make it feel faster. If you can, go for a timed ride on your bike, then on a different brand. Which was faster? Which one tired you out more?
  • ace402
Posted March 09, 2009 - 06:53 AM
+1!!!
  • MX926
Posted March 09, 2009 - 07:13 AM
Change pipe...........go ride............enjoy your new bike.
  • erickdj
Posted March 09, 2009 - 08:48 AM
The engine comment I can understand, but the suspension complaint? That just doesn't make sense. It's been called one of the best, if not the best suspension out of production bikes, and I have to say that it is VERY good. I'm 185lbs, not the fastest around, but I can push it hard. 2 clicks on the suspension and I'm the happiest one around with the suspension, stock. Maybe this guy is used to ride bikes with top of the line factory suspension.:ride: :p
Like the others said, change the exhaust, even just a slip-on or a stock muffler from an 06 bike, that will fix the power curve instantly. And the suspension..... well, if you think the kx will have better suspension, think again.
  • Kalar01
Posted March 09, 2009 - 08:54 AM
I ride an 08 450 in the utah desert & as much single track as I can get. This is the best bike I have ever had for this area. I shift less than on my KTM and can ride ALOT longer. When I want more power I just twist my right hand more....
  • Wiz636
Posted March 09, 2009 - 08:58 AM
I want to ride the 125 he's talking about!
  • erickdj
Posted March 09, 2009 - 10:23 AM
yep, that's right. I have an 08 as well, it's only got a Dr.D exhaust as far as performance mods go. It has tremendous pulling power, I mostly leave it in 2nd/3rd gear and take it from there with the throttle.
That would be nice, a 125 that pulls as hard as the 450 on top, where can I buy one?
  • yzinger6
Posted March 09, 2009 - 10:38 AM
I have RARELY used first, and live in 3rd gear. this bike pulls no matter where you are! and the suspension is amazing. What exactly are you missing? power wheelie in 5th not enough? haha
  • 08YZ450Derek
Posted March 09, 2009 - 01:31 PM
Finally got to ride my 08 450.My 450 rips! I have it geared 13/50 and have an exhaust. I can't believe the power,and this is my first 4 stroke and 450. It is almost as much power as a CR500 that I used to race. I have to slow down for the corners soon after the bike lights up! I have not even been on a track yet, just riding it in a small field at my barn. This bike is amazingly fast, I was a B rider and its enough for me. I never rode it with the stock pipe and gearing. Was it that bad?
  • yzinger6
Posted March 09, 2009 - 01:34 PM
my bike is bone stock atm, and I really don't feel I need a pipe. I was just going to bolt on a spark arrester for Ca and call it good. plenty of bike. and I can't even out-ride it stock, so why would I want anything else...
  • TD-3
Posted March 09, 2009 - 02:03 PM
1 post....I say he's trolling:lame:
  • jasonbla
Posted March 09, 2009 - 05:05 PM
I bought the bike from a 230 pounder way out in beryl Ut (5 hours one way). I got it back to my house at 4:30 a.m. then went riding at 8:30. I didn't set the sag or adjust the clickers that's why I was bitching about the suspension. my 05 has revalved suspension and a pipe. It pulls forever, I love the powerband. The yamaha felt light though, really easy to throw around. I loved my honda because I could ride the bike a gear high, the yamaha wants to rev and the bottom end is soft so I was shifting more. Will just a slip on give the bike more snap? or do I need the headpipe also? do the aftermarket pipes stick out way past the side panel?
  • ajwesolowski
Posted March 09, 2009 - 05:07 PM
I have a bone stock 08 yz450f and my buddies have a 05 crf 450, 08 crf 450, and 06 yz450f with yoshi exhaust and yesterday we all drag raced!!! i smoked all of them with 08 yz450f even stock with shit ass exhaust!! RIPES IN HIGH RPMS!!
  • Slinkyman16
Posted March 09, 2009 - 05:23 PM
yes.. they stick out past the side panels. some more then others..
for the price of a slip on u can get almost get a full system custom made by MRDracing.. lifetime warrenty and just tell him you want more bottom and he will give u a pipe that will give u more bottom..
the suspension is going to be way still and u will need to get new springs and a revalve if he did that before he sold it or u wont ever be happy..
  • hillclimbguy
Posted March 09, 2009 - 10:55 PM
Oh man dont go green. Get the exhaust. Should be plenty of 06 mufflers out there. Never heard a problem with the suspension. We have a Dr. D complete exhaust. Nice system. It was worth the money. I think you'll be sorry if you go green.
  • KAS
Posted March 10, 2009 - 10:56 AM
Exhaust first.
Beyond that, I've heard of people swapping the exhaust cam for an '06 cam. Can't say for sure how that works as I've never done it.
  • 10 replies
  • Hot  50 replies
  • Hot  30 replies
  • 0 replies
