yz or wr?
7 replies to this topic
  • ozonefirefighter
Posted March 08, 2009 - 10:06 AM
ok i was going in to put a new timing chain in and bought the flywheel puller for my yz400. I opened up the side cover and removed the nut and went to put the puller and realized there wasnt any threads where i needed them for the puller. got to looking at it and i think the flywheel is a wr. Is my bike a wr? How can i tell? it dosnt have any lights and is only kickstart no e start so i fiured it was yz. No title with it obviously
  • 426 NOOB
Posted March 08, 2009 - 12:50 PM
does it have a kickstand? what size gas tank.
  • 02WR426Cali
Posted March 08, 2009 - 01:14 PM
Is the subframe steel or aluminum? That may be one way to tell, at least on the 426s not positive on the 400s. What size is the rear rim? 18=wr 19=yz stock. Check out the right front wheel spacer, is it an aluminum spacer or is it a black plastic odometer hookup/spacer? Or you could just check the vin....
  • ozonefirefighter
Posted March 09, 2009 - 03:54 AM
ok the subframe is steel it has the black odometer wheel spacer but the rear tire is a 19''. Im thinking it was origionally a wr it does have a kick stand did they make them wo lights? How do i check the vin?
  • ozonefirefighter
Posted March 09, 2009 - 06:11 AM
if it was a wr how hard is it to put lights on the bike i would love lights
  • 02WR426Cali
Posted March 09, 2009 - 06:24 AM
Well you'd have to make sure it has all the proper wiring. Check to see if it has a voltage regulater bolted on the left side of the steering head (it's a small metal peice with fins and a couple wires coming out of it). And under the tank there is a connecter for the headlight coming out of the wire loom under right around where the carb is at. And there is also a couple wires for the tailight that are usually on top of the airbox. Then you would have to buy a headlight and a tailight if you want that. If it does not have these than you will have to get an aftermarket kit like baja designs or whoever else makes one.
  • ozonefirefighter
Posted March 09, 2009 - 10:57 AM
so you think it is a wr?
  • 02WR426Cali
Posted March 09, 2009 - 12:51 PM
It's hard to say without looking at it. You said it had the odo spacer, a kickstand, but it had a 19" rear. If it has the lighting stuff I mentioned above, and the kickstand is not something welded on or aftermarket I would say that it's a wr. You said it also has a wr flywheel so that makes it more likely that it is a wr. Find out how you can check with the vin number, maybe search this site for info. on that because I don't know.
