clutch hard to pull
8 replies to this topic
  • jtn 06 wr450
Posted March 06, 2009 - 08:28 AM
on my 06 wr its way to hard to pull, i have had many look at it and say the same thing.
what would cause this?
i have checked the cables and they move freely, routed right lubed etc.
i tried to move the clutch lever on top of the tranny and i cant move it by hand like my wifes ttr.
does this mean its time for a new clutch? are all wr's like this?
  • William1
Posted March 06, 2009 - 10:26 AM
You'd be surprised. A disconnected cable can seem to slide fine but once it is installed and under tension, the worn areas make themselves know. Replace the cable.
  • jtn 06 wr450
Posted March 06, 2009 - 12:42 PM
its a brand new custom extended cable by motion pro, are they known to be junk?
  • William1
Posted March 06, 2009 - 03:37 PM
LOL, as I noticed you response, another though came to mind, a real worn lever pivot can also cause increased lever effort.
Motion Pro cables are supposedly good stuff. I have never used one though. If your lever is in good condition (was the action good with your old cable?) then perhaps there is a fault with the new cable. Nothing is always perfect.
  • Krannie McKranface
Posted March 06, 2009 - 05:49 PM
LIke william said, worn pivot points are usually overlooked. Look at the point where the cable ends are leveraged, and see if the device they fit into are still perfectly cylindrical in shape. I've seen levers that are toast on the pivot, that make the clutch seem seized.
  • DrBosa
Posted March 09, 2009 - 11:23 AM
My clutch was also a bitch to pull. Simply changing the cable didn't do it, but after cleaning and lubing the lever pivot with fork oil (and the cable itself while at it) it became pretty decent.
  • jtn 06 wr450
Posted March 11, 2009 - 07:36 AM
i sprayed teflon lube into the cable and it helped. compared to most cable clutches it is still stiff. i pulled on the clutch push lever going into the clutch housing and couldnt even make it budge with my fingers. no wonder the cable seems tight. are your wr 450 clutch push levers the same?
  • WR450FGreg
Posted March 11, 2009 - 10:43 AM
This is normal for pretty much any bike.
I agree with the guys, check that lever/bracket pivot point.
Greg
  • jtn 06 wr450
Posted March 12, 2009 - 06:46 AM
greased the pivot point and the cable ends with white lithium and it looked to be in good condition
