Who Services Their Own Scott's Dampener???
6 replies to this topic
  • Dodger
Posted August 07, 2002 - 09:02 PM
What's involved and is there much to it??? I read in the manual that your supposed to send your dampener into Scotts after the first 40 hrs of riding. Since I am way over the first 40 hrs I decieded to call Scotts to get some info. The guy at Scotts asked how long I've had it, (about 6 months now), and said there was no reason that I should need to send it in. He said just change out the oil, ride for another 4 - 6 months, and then look at sending it in for sevice. (That's all baring a get off of course!)
So, I'm assuming that this is an easy process....do I buy special oil from Scotts??
Thanks in advance.........
Dodger :) :D
  • Merfman
Posted August 07, 2002 - 10:03 AM
Hey Dodger,
I just did mine. There's no mystery except when replacing the oil. You MUST do as they recommend in the instructions.
Go to:
http://www.scottsper.../indexmain.html
and download the instructions. It's pretty simple and I was amazed at how much better it worked with fresh fluid.
And, BTW, instead of using their special tool, I just picked up a syringe at the local vet supply store.
Merf
[ August 07, 2002: Message edited by: Merfman ]
  • YZ400Court
Posted August 07, 2002 - 04:41 PM
I also did mine. It was easy. It began leaking after a get off. I tore it apart, cleaned up the seals, put new 2 wt fork oil in and had no problems since.
  • sabin
Posted August 07, 2002 - 09:00 PM
Hey guys,
what is this daper good for? Does it worth the money? How is Ohlins damper compared to scott?
Thanks for the info :)
  • YZ400Court
Posted August 08, 2002 - 03:35 AM
The Scotts and Ohlins are the same, both made by Ohlins. I would say it is the single biggest improvement you can make for riding sand, roots or rocks. Also VERY helpful in the scary fast stuff.
  • Merfman
Posted August 08, 2002 - 05:23 AM
I would agree with Mr Court. I view mine as safety equipment.
Merf
  • Merfman
Posted August 08, 2002 - 09:50 PM
Dodger, check your PM's...
Merf
