1999 WR 400 Compression Release Oil Leak
3 replies to this topic
  • alindbla
Posted March 02, 2009 - 08:05 PM
I just bought a 1999 wr 400 and I noticed that the compression release is leaking a little bit of oil. It leaks while I am riding, not just when I use it. This is the first bike I have owned and am not quite sure what to do. I would appreciate any ideas and suggestions anyone would have.
Thanks,
Alex
  • matt4x4
Posted March 03, 2009 - 05:16 AM
Replace part #15 - it's a 10 minute $5 fix.
Just make sure it's leaking there and not on bolt #13 - if it';s leaking on bolt #13, replace washer #14
  • alindbla
Posted March 03, 2009 - 02:42 PM
Thanks, I will replace that part and see if it stops the leak.
  • maxtherat
Posted March 03, 2009 - 06:18 PM
Be cafeful when you tighten screw #13. It can strip very easily. A little suggestion, after lever is removed, use an allen wrench to push out the seal from the inside out by putting the short angled end of the allen through the hole for bolt #13. There is a small tensioning spring inside the lip of the seal that could possibly popout into the motor while trying to remove the seal.
