Mud in engine
19 replies to this topic
  • IFOL519
Posted March 02, 2009 - 12:42 PM
I recently raced a hare scramble and I got stuck in the mud. It took 5 guys and about two hours to get my bike out. When we got the bike out and started it it made a strange noise but it still ran. When I got home I checked the radiators and they were empty and the I checked the oil and mud started to come out. I used oil and air to try and get it out but some mud is still coming out. What should I do? Do I keep doing this? I have not started the bike again
I run a 2007 yz450f
thanks
  • psellers22
Posted March 02, 2009 - 12:46 PM
I run a 2007 yz450f
thanks
i would at least pull of the crankcase cover on both sides and inspect..but for on the radiators being completely empty i would be reaaaaally worried unless you find a hole in the cores somewhere....goodluck glad it not me :p and if it were me because im ocd with my bike i would take the motor out and tear it down and check everypart on it !!
  • jo-hn1777
i'd say if you really want to get it all out you're going to have to split the cases
  • kawasakimx8
Posted March 02, 2009 - 12:51 PM
split the cases, clean inspect, and assemble, and then flush it a couple times using some kind of cheap oil. then dump some good in and run it, after about 45 min, to 1 hour of riden, empty it out and change oil filter and oil.
Posted March 02, 2009 - 12:52 PM
No shortcuts. Tear the whole thing down and do it right. The potential expense in the alternative is just too big.
  • IFOL519
Posted March 02, 2009 - 02:46 PM
Thanks for the responses
I will open the motor and clean it out
  • ThumperKid250F
Posted March 02, 2009 - 07:16 PM
i would tear that whole motor apart no questions asked. i wouldent be surprise if you have to replace a lot of parts inside..
ie. clutch, bearings, valves ect..
  • dylans503
Posted March 02, 2009 - 07:21 PM
wow sucks man. its probably best that you tear it down
  • etug321
Posted March 03, 2009 - 08:40 AM
Make sure you disassemble the oil pump and clean it. Grit will grind into the case if left untouched.
  • 642MX
Posted March 03, 2009 - 04:53 PM
I would just replace the oil pump and rotor, along with the main bearings and big end bearing (and anything else that doesn't look right).
  • simonrsv
Posted March 03, 2009 - 05:22 PM
Sorry to here that, I had a wr 426 only 200 miles old that got stuck in deep
mud , we had the same problem the bike would not start ,when we got it running rode 5 miles home,the engine was full of mud so we stripped the motor . I had to change oil pump,engine bearing, camshaft, piston and barrel
, the mud had blocked all the oil feeds and the mud must have been quite sandy because it looked like someone had shot blasted the internals.
I hope you have better luck
  • IFOL519
Posted March 06, 2009 - 09:32 AM
Well as you guys said I took my motor to my mechanic and he opened it up and it was not pretty. Now I need to find alot of part so I was wondering if you guys knew were to get oem parts at low cost.
Posted March 06, 2009 - 09:38 AM
http://shop.thumpertalk.com/oem.asp
  • IFOL519
Posted April 01, 2009 - 02:13 PM
I have purchased some of the parts I need such as the cylinder, piston and gaskets, but the head also was damaged so I need another one, my mechanic says he has one but he doesnt have the buckets that go ontop of the valves. The problem is I cant find were they sell them, I looked at the TT store but I could find them, anyone know were I could purchase them?
thanks for all the help
Posted April 01, 2009 - 02:21 PM
Yamaha (or TT OEM). Right there on the Valve page in the parts book:
3FV-12153-10-00 (5 required )
  • IFOL519
Posted April 01, 2009 - 02:37 PM
I feel stupid now.
I was looking in the wrong place.
thanks
  • schrode
Posted April 01, 2009 - 02:40 PM
upside is you're going to have a brand new motor when all is said and done
Posted April 01, 2009 - 03:06 PM
I feel stupid now.
thanks
It takes a while to get the hang of the parts book layout.
  • Stupendous
Posted April 01, 2009 - 03:30 PM
www.servicehonda.com (yes they sell Yamaha) is actually cheaper so make sure you get TT to do the 110% price match difference. I just recently priced parts between the two sites when I was purchasing some OEM parts.
  • Pilfer8
Posted April 01, 2009 - 03:53 PM
http://cheapcyclepar...om/Street.aspx#
use the tt price guarantee:thumbsup:
  • Hot  28 replies
  • 10 replies
  • On January 15, 2017
  • Hot  113 replies
