DP clutch problems
7 replies to this topic
  • trevorchappell
Posted February 27, 2009 - 07:12 PM
I just bought a new dp clutch for my 08 yz 450 and it came with 9 fibers and stock has 8 . Evin when i put 8 of the dp plates in the clutch still won't dissengage ( with adjusters all the way out ) the only way i can get it to disengage is to use 7 fibers and stack 2 steel plates together. I have not ran the bike yet and think the kit may have been miss packaged ( cheked the part # twice and it is the right one ) I was wondering if there was something that i was missing.
Posted February 27, 2009 - 08:24 PM
The clutch kit for an '07 and later should be different from the 9 plate stack for the '06 and earlier models in more ways than the number of plates.
The thickness of the steel plates is different, the springs are different and the pressure plate is different, as is the release arm. Unless these parts are changed to match those in the '06, I don't see this setup working.
The only chance you might have of using these new friction plates is to use them with the correct OEM steel plates.
Essentially, it would appear you have the wrong parts.
  • trevorchappell
Posted February 28, 2009 - 06:38 AM
thanks for the help ... the part # i ordered was for an 07-08 450 ... mabyee dp packaged it wrong .... i will try to contact them and see if they can send me another one ... thanks I appriciate your reply
  • bnyfe
Posted February 28, 2009 - 07:21 PM
Hey guys...I have always used the stock clutch in everything. But because the clutch is a weak link on the 08 YZ450F (can't stand up to much abuse) Do you guys know of an after market that holds up under abuse in the 08.
Please only if you clutch a lot and only if you know for certain. Opinion based on factual experience in this bike.:lol:
Thanks
Posted February 28, 2009 - 07:34 PM
Convert it to an '06 clutch. Use the '06 plate set, springs, pressure plate, and release arm.
  • bnyfe
Posted February 28, 2009 - 08:09 PM
thanks...what does this do different to make the clutch last better?
Posted February 28, 2009 - 08:43 PM
9 plates vs. 8, for one thing. 12% more clutch with more spring pressure. Should still be easy to pull; both mine are.
  • bnyfe
Posted March 01, 2009 - 04:50 AM
Hey...thanks very much for the information Gray.
I'll give it a try..:lol:
  • Hot  50 replies
  • Hot  38 replies
  • On January 15, 2017
  • 5 replies
