26mm socket for primary nut fix
4 replies to this topic
  • CoolHands
Posted February 26, 2009 - 02:29 AM
I bought a 26mm (6 sided) socket specifically to hold the stator plate side nut to tighten the primary clutch nut. But, it does not fit!!! :lol: I read the instructions in the FAQ and most people use a 26mm spanner, heated and bent to shape.
But, that doesn't explain why my socket won't work? ??? It simply doesn't fit over. A 27mm socket seems a little loose.
Can anyone explain?
  • Erik Marquez
Posted February 26, 2009 - 02:37 AM
Can anyone explain?
It is a cast part of the flywheel, not a precision fastener. Your using a 6 sided socket, the wrench we used to make the tool is a 12 point. That is one possibility, another is that the hex cast on your flywheel is not 26mm … So, use what ever fits. SAE, or 27mm, or, grind a bit off the flats of the hex with a carbide bit, or………many possibilities, pick a solution that works for you.
  • GuyGraham
Posted February 26, 2009 - 04:35 AM
My 26mm deep socket was a tight fit, as Bronco says, its not a proper fastener
Tap it on lighlty with a hammer - its what I had to do
Goes on easy the second time
  • CHEFonDRZSM
Posted February 28, 2009 - 03:12 PM
Good to know, maybe add this as part 2 in the sticky:thumbsup:
  • Erik Marquez
Posted February 28, 2009 - 09:31 PM
When I have some time I will. Thanks
I think I am too stupid to install throttle cables... by razzledazzle
  • Hot  46 replies
Desert SuperMoto by alpha_nett
  • Hot  60 replies
Suzuki DR-Z400E 2016 by DirtShow
  • 0 reviews
My dirtbike accedent that just changed my life by Colorado dirt bike kidz
  • Hot  142 replies
Upgrading from S to SM forks and rear axle worth it? by arpuS
  • Hot  50 replies
