Temp Correction
1 reply to this topic
  • HaremScarem
Posted August 05, 2002 - 10:54 AM
I have a 2002 426 wit hthe lid off and uncorked.
Stock jetting. The bike has lost it's snap when cracking the throttle. I think it's because of the High temperatures and Humidity.
The stock jetting is ..
42 PJ
DRR 4th clip
I was going to reduce the size of the Main jet to a 160 and raise the clip to the 3rd slot. The as found factory setting on the fuel screw was 2 turns out. I was thinking of reducing this to
1 1/2 turns out.
Please tell me if I'm on the right track or do you guys suggest something else?
  • Hick
Posted August 05, 2002 - 03:02 PM
Just ignore me, because I always say the same thing, and that is:
Uncorked/uncovered WR is pretty much a stock YZ, so why not try YZ jetting (basically a needle change).
I've jetted three WR 426s, and used E tapers in all of them, all at higher altitudes too, and all ran much better than with the stock D.
Granted, that was the only D needle I tried, but IMO once you rid the WR of all that silliness you should just jet it like a YZ.
In my experience the cam timing (which I tried on one WR) has no effect on the jetting.
Disabling the air cut valve does seem to clear up what can be a little weirdness at lower throttle and idle also, but any serious bog is going to be on your pilot and needle IMO...
