Is my shock alright?
5 replies to this topic
  • Navaho6
Posted February 25, 2009 - 07:00 PM
I bought an '06 WR450 last month. When I pull up on the rear and the shock tops out, it is a hard "clunk". Don't know if this is normal for a Yamaha but none my other bikes have done this.
  • TonyR
Posted February 26, 2009 - 01:14 AM
It would be worth checking the bearing at the bottom of the shock first, as the clunking sound may only appear to be comming from inside the shock.
I would also check swingarm and linkage bearings for movement and the top shock bearing although they normally don't wear as fast as the bottom one.
The only clunking sound I have experienced has been a bearing worn.
However it may be due for a shock service anyhow.
  • Navaho6
Posted February 26, 2009 - 08:02 AM
The bike only has 900 miles on it. The bearings are tight. There is no movement or loose feeling either. It's when I top out the shock by pulling all the way up, there is rigid hit but no loose parts. I had a KTM previously and it had a top out spring that I am guessing the Yami doesn't have.
  • TonyR
Posted February 26, 2009 - 01:58 PM
There is no top out spring, and you can hear the shock or linkage top out, but I would describe it more as a muffled noise than clunking. If all linkages are tight then it is probably normal, but you could check by comparing another WR with yours to be sure.
  • Navaho6
Posted February 26, 2009 - 03:11 PM
It not so much of a noise, just a feeling of a sudden stop.
  • Navaho6
Posted February 26, 2009 - 07:35 PM
Checked out a YZ tonight. It's a normal Yamaha thing. No top out spring is the reason.
